digitalWrite pins 0 and 1
Hello I am trying to use the digital pins 0 and 1 (RX, TX) like one of the other ones. I upload the program led blink but with led_pin = 0. Then I reset the board, desconect the USB cable but the pin doesn´t blink. Any help? I have to use pins 0 and 1because I need at least 13 OUTPUT digital pins for my installation.
Any help?
I found that , but doesnt solve my problem.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1138285049
I think you have to turn off the serial port before you can use pins 0 and 1 as normal digital pins. Try adding this to your setup:
      outb(UCSRB, 0);
It doesnt compile.
In function 'void setup()': error: 'outb' was not declared in this scope
Whoops, try instead:
UCSRB = 0;
neither does it.
In function 'void setup()': error: 'UCSRB' was not declared in this scope
If you're using an ATmega168, you'll need to use this instead:
UCSR0B = 0;
If you're using an ATmega8, it's strange that it doesn't work. Which version of Arduino are you using?
Great Did work. I own u one. :D
