digitalWrite question (solved)
I am writing a sketch where I need a pin (pin 5 7) to go to LOW under a certain condition. I am using it as a 'relay' to control another board which does its thing when I ground the signal. I was hoping to be able to ground the signal through the pin and not use another part.
Problem is, pin 5 7 seems to go LOW at the start of the program and 'stays' there. So it triggers my other board when I first reset the sketch but not when the IF condition has been met.
Here is the code -
  Wire.begin();
  bmp085Calibration();
  temperature = bmp085GetTemperature(bmp085ReadUT());
  pressurex = bmp085GetPressure(bmp085ReadUP());
  pressureCall = (pressurex - 20);
  Serial.print(pressurex);
  Serial.print(pressureCall);
  pinMode(13, OUTPUT);
  pinMode(7, OUTPUT);
  pressure = bmp085GetPressure(bmp085ReadUP());
     Serial.print("Temperature: ");
  Serial.print(temperature, DEC);
  Serial.println(" *0.1 deg C");
  Serial.print("Pressure: ");
  Serial.print(pressure, DEC);
  Serial.println(" Pa");
  altitude = (float)44330 * (1 - pow(((float) pressure/p0), 0.190295));
  Serial.print("Altitude: ");
  Serial.print(altitude, 2);
  Serial.println(" m");
  if (pressure < pressureCall)
    digitalWrite(13, HIGH);
    digitalWrite(7, LOW);
    Serial.print("You Are High!");
    while(1);
Any ideas?
Your code mentions pin 7 and pin 13, but not pin 5...
I presume you forgot to set the output state to HIGH before enabling it:
  digitalWrite (pin, HIGH) ;
  pinMode (pin, OUTPUT) ;
I see no code that mentions pin 5 in any way?!?
I see no code that declares temperature, or pressure, or...
I don't see any CODE TAGS either. :0
hee hee apart from that - spot on!
mmcp42:
My goof - meant Pin 7
I don't want it set to HIGH is if I can avoid it.
But I think I figured it out with this -
Instead of setting pinMode in setup I put it in the routine after the condition
Here is the updated code - (by the way this is just a snippet of the whole code)
  Wire.begin();
    pinMode(7, OUTPUT);
    while(1);
AWOL:
This was just a bit of the code... //sorry to raise your ire with the lack of CODE TAGS
so put [ code] in front of it
[ /code] at the end of it
Don't worry, I've added them.
AWOL:
Thanks. Newbie goof...
