What do I need to add to the digitalWriteFast library to give it Atmega1284P support?
It compiles in 1.8.5 with the Mightycore 1284 and Bobuino pinout, but I don't think it's actually doing anything since there's no section like this
#if defined(AVR_ATmega1280) || defined(AVR_ATmega2560)
for the 1284P in it.
I'd got it added to the Stepper.h library to replace the digitalWrite() statements.
If something better has become available since 2010 to replace this, I could use that instead.
Thanks
PA0 to PA7 are D21, 20, 19, 18, 17, 16, 15, 14
PB0 to PB7 are D4, 5, 6, 7, 10, 11, 12, 13
PC0 to PC7 are D22, 23, 24, 25, 26, 27, 28, 29
PD0 to PD7 are D0, 1, 2, 3, 30 ,8 ,9 ,31
I commented out the first 2 lines to get it to compile.
https://code.google.com/archive/p/digitalwritefast/downloads
(forum may stick extra characters at start and end of that, hover over it to check)
// #include "WProgram.h"
// #include <wiring.h>
#define BIT_READ(value, bit) (((value) >> (bit)) & 0x01)
#define BIT_SET(value, bit) ((value) |= (1UL << (bit)))
#define BIT_CLEAR(value, bit) ((value) &= ~(1UL << (bit)))
#define BIT_WRITE(value, bit, bitvalue) (bitvalue ? BIT_SET(value, bit) : BIT_CLEAR(value, bit))
#if !defined(digitalPinToPortReg)
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
// Arduino Mega Pins
#define digitalPinToPortReg(P) \
(((P) >= 22 && (P) <= 29) ? &PORTA : \
((((P) >= 10 && (P) <= 13) || ((P) >= 50 && (P) <= 53)) ? &PORTB : \
(((P) >= 30 && (P) <= 37) ? &PORTC : \
((((P) >= 18 && (P) <= 21) || (P) == 38) ? &PORTD : \
((((P) >= 0 && (P) <= 3) || (P) == 5) ? &PORTE : \
(((P) >= 54 && (P) <= 61) ? &PORTF : \
((((P) >= 39 && (P) <= 41) || (P) == 4) ? &PORTG : \
((((P) >= 6 && (P) <= 9) || (P) == 16 || (P) == 17) ? &PORTH : \
(((P) == 14 || (P) == 15) ? &PORTJ : \
(((P) >= 62 && (P) <= 69) ? &PORTK : &PORTL))))))))))
#define digitalPinToDDRReg(P) \
(((P) >= 22 && (P) <= 29) ? &DDRA : \
((((P) >= 10 && (P) <= 13) || ((P) >= 50 && (P) <= 53)) ? &DDRB : \
(((P) >= 30 && (P) <= 37) ? &DDRC : \
((((P) >= 18 && (P) <= 21) || (P) == 38) ? &DDRD : \
((((P) >= 0 && (P) <= 3) || (P) == 5) ? &DDRE : \
(((P) >= 54 && (P) <= 61) ? &DDRF : \
((((P) >= 39 && (P) <= 41) || (P) == 4) ? &DDRG : \
((((P) >= 6 && (P) <= 9) || (P) == 16 || (P) == 17) ? &DDRH : \
(((P) == 14 || (P) == 15) ? &DDRJ : \
(((P) >= 62 && (P) <= 69) ? &DDRK : &DDRL))))))))))
#define digitalPinToPINReg(P) \
(((P) >= 22 && (P) <= 29) ? &PINA : \
((((P) >= 10 && (P) <= 13) || ((P) >= 50 && (P) <= 53)) ? &PINB : \
(((P) >= 30 && (P) <= 37) ? &PINC : \
((((P) >= 18 && (P) <= 21) || (P) == 38) ? &PIND : \
((((P) >= 0 && (P) <= 3) || (P) == 5) ? &PINE : \
(((P) >= 54 && (P) <= 61) ? &PINF : \
((((P) >= 39 && (P) <= 41) || (P) == 4) ? &PING : \
((((P) >= 6 && (P) <= 9) || (P) == 16 || (P) == 17) ? &PINH : \
(((P) == 14 || (P) == 15) ? &PINJ : \
(((P) >= 62 && (P) <= 69) ? &PINK : &PINL))))))))))
#define __digitalPinToBit(P) \
(((P) >= 7 && (P) <= 9) ? (P) - 3 : \
(((P) >= 10 && (P) <= 13) ? (P) - 6 : \
(((P) >= 22 && (P) <= 29) ? (P) - 22 : \
(((P) >= 30 && (P) <= 37) ? 37 - (P) : \
(((P) >= 39 && (P) <= 41) ? 41 - (P) : \
(((P) >= 42 && (P) <= 49) ? 49 - (P) : \
(((P) >= 50 && (P) <= 53) ? 53 - (P) : \
(((P) >= 54 && (P) <= 61) ? (P) - 54 : \
(((P) >= 62 && (P) <= 69) ? (P) - 62 : \
(((P) == 0 || (P) == 15 || (P) == 17 || (P) == 21) ? 0 : \
(((P) == 1 || (P) == 14 || (P) == 16 || (P) == 20) ? 1 : \
(((P) == 19) ? 2 : \
(((P) == 5 || (P) == 6 || (P) == 18) ? 3 : \
(((P) == 2) ? 4 : \
(((P) == 3 || (P) == 4) ? 5 : 7)))))))))))))))
// 15 PWM
#define __digitalPinToTimer(P) \
(((P) == 13 || (P) == 4) ? &TCCR0A : \
(((P) == 11 || (P) == 12) ? &TCCR1A : \
(((P) == 10 || (P) == 9) ? &TCCR2A : \
(((P) == 5 || (P) == 2 || (P) == 3) ? &TCCR3A : \
(((P) == 6 || (P) == 7 || (P) == 8) ? &TCCR4A : \
(((P) == 46 || (P) == 45 || (P) == 44) ? &TCCR5A : 0))))))
#define __digitalPinToTimerBit(P) \
(((P) == 13) ? COM0A1 : (((P) == 4) ? COM0B1 : \
(((P) == 11) ? COM1A1 : (((P) == 12) ? COM1B1 : \
(((P) == 10) ? COM2A1 : (((P) == 9) ? COM2B1 : \
(((P) == 5) ? COM3A1 : (((P) == 2) ? COM3B1 : (((P) == 3) ? COM3C1 : \
(((P) == 6) ? COM4A1 : (((P) == 7) ? COM4B1 : (((P) == 8) ? COM4C1 : \
(((P) == 46) ? COM5A1 : (((P) == 45) ? COM5B1 : COM5C1))))))))))))))
#else
// Standard Arduino Pins
(((P) >= 0 && (P) <= 7) ? &PORTD : (((P) >= 8 && (P) <= 13) ? &PORTB : &PORTC))
(((P) >= 0 && (P) <= 7) ? &DDRD : (((P) >= 8 && (P) <= 13) ? &DDRB : &DDRC))
(((P) >= 0 && (P) <= 7) ? &PIND : (((P) >= 8 && (P) <= 13) ? &PINB : &PINC))
(((P) >= 0 && (P) <= 7) ? (P) : (((P) >= 8 && (P) <= 13) ? (P) - 8 : (P) - 14))
#if defined(__AVR_ATmega8__)
// 3 PWM
(((P) == 9 || (P) == 10) ? &TCCR1A : (((P) == 11) ? &TCCR2 : 0))
(((P) == 9) ? COM1A1 : (((P) == 10) ? COM1B1 : COM21))
#else //168,328
// 6 PWM
(((P) == 6 || (P) == 5) ? &TCCR0A : \
(((P) == 9 || (P) == 10) ? &TCCR1A : \
(((P) == 11 || (P) == 3) ? &TCCR2A : 0)))
(((P) == 6) ? COM0A1 : (((P) == 5) ? COM0B1 : \
(((P) == 9) ? COM1A1 : (((P) == 10) ? COM1B1 : \
(((P) == 11) ? COM2A1 : COM2B1)))))
#endif //defined(__AVR_ATmega8__)
#endif //mega
#endif //#if !defined(digitalPinToPortReg)
#define __atomicWrite__(A,P,V) \
if ( (int)(A) < 0x40) { bitWrite(*(A), __digitalPinToBit(P), (V) );} \
else { \
uint8_t register saveSreg = SREG; \
cli(); \
bitWrite(*(A), __digitalPinToBit(P), (V) ); \
SREG=saveSreg; \
#ifndef digitalWriteFast
#define digitalWriteFast(P, V) \
do { \
if (__builtin_constant_p(P) && __builtin_constant_p(V)) __atomicWrite__((uint8_t*) digitalPinToPortReg(P),P,V) \
else digitalWrite((P), (V)); \
}while (0)
#endif //#ifndef digitalWriteFast2
#if !defined(pinModeFast)
#define pinModeFast(P, V) \
do {if (__builtin_constant_p(P) && __builtin_constant_p(V)) __atomicWrite__((uint8_t*) digitalPinToDDRReg(P),P,V) \
else pinMode((P), (V)); \
} while (0)
#endif
#ifndef noAnalogWrite
#define noAnalogWrite(P) \
do {if (__builtin_constant_p(P) ) __atomicWrite((uint8_t*) __digitalPinToTimer(P),P,0) \
else turnOffPWM((P)); \
} while (0)
#endif
#ifndef digitalReadFast
#define digitalReadFast(P) ( (int) _digitalReadFast_((P)) )
#define _digitalReadFast_(P ) \
(__builtin_constant_p(P) ) ? ( \
( BIT_READ(*digitalPinToPINReg(P), __digitalPinToBit(P))) ) : \
digitalRead((P))
#endif
