Hi everybody,
I was curious and wanted to test the digitalWriteFast function for later use in time critical applications.
Therefore I did as suggested: I put the folder called digitalWriteFast, containing digitalWriteFast.h and a keyword file, into my arduino library alongside the EEPROM, Ethernet, Firmata, etc folders..
However, if I compile the simple sketch below I get the following error messages:
Blink_with_digitalWriteFast.cpp: In function 'void loop()':
Blink_with_digitalWriteFast:14: error: invalid type argument of 'unary *'
Blink_with_digitalWriteFast:16: error: invalid type argument of 'unary *'
I really don't understand that. Any ideas?
I am working with an Arduino UNO and arduino 1.0.1 at the moment.
Any help or hints would be highly appreciated. Thanks!
#include <digitalWriteFast.h>
int led = 13;
pinMode(led, OUTPUT);
digitalWriteFast(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWriteFast(led, LOW); // turn the LED off by making the voltage LOW
Hi Nick, hi everybody,
unfortunately yes, I restarted my IDE.
I also just restarted my computer and I got the same error message:
Blink_with_digitalWriteFast:9: error: invalid type argument of 'unary *'
Blink_with_digitalWriteFast:11: error: invalid type argument of 'unary *'
I know this is weird, as I also expected it to work.
Can it have something to do with my operating system???
I am currently working with Windows XP.
Unfortunatey using the modified code below I get the same error message.
I am puzzled at the moment.
Any further suggestions???
#include <digitalWriteFast.h> #define led 13
When I migrated to IDE 1.6.5r5, I had errors during compile. Modifying the digitalWriteFast.h file as mentioned by heX1625616 worked. I also had problems with the location of the digitalWriteFast directory; I had used the windows installer for the installation of the IDE. I now only use the portable (non Administrator version). I have to put the digitalWriteFast into sketch\libraries directory. I was also having problems with the Wire library until I installed it into the sketch\libraries directory.
