After doing some searching and learning, I’ve been able to read the incoming data from those cheap digital callipers and got it displaying both metric and inches on a LCD.
Now I would like to add an 7 segment display using a Max7219 but seem to be struggling on how to get it work, The code below is what I am trying it’s kind of displaying some data but not the correct data.
I only want it to display the metric reading, I’m trying to get my head around on how to get it to display the reading like it on the LCD. LCD displays 13.3350 and on the LED display only 333.1 ?.
I tried watching videos done lots of playing but cant get my head around, I’d be grateful if someone could point me in the right direction.
Here’s the cod I have working
#include <PinChangeInt.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
//#define DEBUGLCD // Flag set for debugging LCD Device operation
//#define DEBUGCALIPER0 // Flag set for Caliper0
#define XCLK_Pin 2
#define XDAT_Pin 3
#define XZERO_Pin 11
//LCD max 7219
int pomocni1;
int pomocni2;
int ostatak1;
int ostatak2;
int pozicija1 = 4;
int pozicija2 = 0;
#include <LedControl.h>
//LedControl lc=LedControl(12,11,10,1);
LedControl lc = LedControl(50, 51, 53, 1);
int xpos = 0;
char cval = 0x70;
// ISR Variables
// X Block
unsigned long pre_posVal0;
unsigned long old_posVal0 = 0;
volatile unsigned long passVal0 = 0;
volatile unsigned long posVal0;
volatile unsigned long intervalT0;
volatile int bitrunner0 = 0;
volatile boolean bitin0;
double metric = 0;
float average = 5.36;
// Static Variables for displaying
long marker0; // Current positions for X, Y, and Z
long oldMarker0 = 0; // Previous positions for X, Y, and Z
long adjuster0 = 0; // Zero positions for reference
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change:
const long interval = 100;
// End Front Matter. Begin SETUP Routine here.
// the setup routine runs once when you press reset:
lc.shutdown(0, false); // Enable display
lc.setIntensity(0, 10); // Set brightness level (0 is min, 15 is max)
lc.clearDisplay(0); // Clear display register
pinMode( XCLK_Pin, INPUT);
pinMode( XDAT_Pin, INPUT);
pinMode( XZERO_Pin, INPUT);
digitalWrite(XZERO_Pin, HIGH); // Enable interna; pullup
lcd.begin(16, 2);
lcd.clear();
#if defined( DEBUGLCD ) || defined( DEBUGCALIPER0 )
Serial.begin(9600); // Wake up the serial line at 9600 baud
Serial.println("\n\nHello World - System Starting.");
#endif
delay(2);
lcd.setCursor(9, 0);
lcd.print("MM");
lcd.setCursor(9, 1);
lcd.print("INCHES");
intervalT0 = micros();
attachInterrupt(0, xclkISR, RISING); // Int zero on pin two
// End Setup. Begin MAIN LOOP Routine here.
// the loop routine runs over and over again forever:
// Check if X is new
if (bitrunner0 == 24) { // we have shifted in a full value
pre_posVal0 = passVal0; // Grab the passed up value before it changes
if ((old_posVal0 != pre_posVal0) || (!digitalRead(XZERO_Pin))) {
old_posVal0 = pre_posVal0;
marker0 = convertCalVal( pre_posVal0 );
if (!digitalRead(XZERO_Pin)) adjuster0 = marker0, metric = 0;
lcd.setCursor(0, 1);
printPosition( marker0 - adjuster0 );
metric = marker0 * 25.4 / 10000;
lcd.setCursor(0, 0);
lcd.print( metric, 4 );
lcd.print(" ");
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
ispisNaLcd1(metric);
lc.setLed(0, 6, 0, true);
long convertCalVal( unsigned long pVal) {
long marker;
marker = (long)((~pVal) & 0xFFFFF) >> 2; // Should be absolute value positive number
marker = marker * 10;
if (!(pVal & 0x02)) marker += 5;
if (!(pVal & 0x200000)) marker = marker * -1;
return ( marker );
void printPosition ( long pVal ) {
if (pVal > 0) {
lcd.write('+');
else {
lcd.write('-');
pVal = 0 - pVal;
// lcd.write(HextoASCII( (unsigned int) (pVal / 100000)));// For greater than 6Ich calpier Not needed for 6"
// pVal = pVal % 100000; // For greater than 6Ich calpier not need fro 6"
lcd.write(HextoASCII( (unsigned int) (pVal / 10000)));
pVal = pVal % 10000;
lcd.write('.');
lcd.write(HextoASCII( (unsigned int) (pVal / 1000)));
pVal = pVal % 1000;
lcd.write(HextoASCII( (unsigned int) (pVal / 100)));
pVal = pVal % 100;
lcd.write(HextoASCII( (unsigned int) (pVal / 10)));
pVal = pVal % 10;
lcd.write(HextoASCII( (unsigned int) (pVal)));
void xclkISR() {
if ((micros() - intervalT0) > 70000) {
bitrunner0 = 0;
passVal0 = posVal0;
posVal0 = 0;
bitin0 = digitalRead(XDAT_Pin);
posVal0 = posVal0 | ( ((unsigned long) bitin0) << bitrunner0++ );
char HextoASCII( unsigned char inbyte)
// take the least signifigant nibble and convert to hex ASCII equivalent
inbyte &= 0x0F;
inbyte += 0x30;
if (inbyte > 0x39) inbyte += 0x07;
return (inbyte);
void ispisNaLcd1(float broj1) //for voltage
pomocni1 = broj1 * 100;
while (pomocni1 > 0)
ostatak1 = pomocni1 % 10;
lc.setDigit(0, pozicija1, ostatak1, false);
pomocni1 = pomocni1 / 10;
pozicija1++;
pozicija1 = 4;
