Hello all, I am having a problem with multiplexing my shift registers and segment displays. I am creating a sim racing button box/ gear and time indicator. I think I have the logic correct in my code, but the last digit in both of my multiplex's wants to start at the front of the code. I have fixed the printGear() method to display it in the right order, but I want to know if there is a way I can do this without changing my wiring or changing digit pins.
I have double checked my wiring pins according to their respective digits, and there is no problem there. I can shift a number to a digit alone and it will show up correctly, but when I start adding multiple digits while multiplexing, it wants to put the last number first.
A Preview, cant see much of the wiring, but g1, g2, and g3 are for the top 3 displays and d1 - d8 are for the bottom displays. all numbers are left to right respectively.
The 6 is the last digit, but it is showing up before the - 1 -. Also if you look closely at the code, you can see I have performed an informal fix on the 3 displays at the top of the breadboards. I would eventually like to take out the initial -, but i thought it would help place the last digit in its place.
Any help would be greatly appreciated!
Here is my Code
