After much cautious soldering, I've got my first decent project finished. The set-up is my arduino (pins: digital 10, 11, 12, 13 & analog 5v and GND). This is hooked up to a 4051 (as a demux) which then runs out 8 outputs to leds (common cathode) with appropriate resistors (on the anode of course).
A number of questions come to mind:
The LEDs are slightly dim. Because I'm rapidly flipping through them, I assume they aren't getting enough current. Are there formulas to calculate a lower resistor value that takes into account the switching frequency?
Are there advantages or disadvantages to which end of the LEDs are common? (anode vs cathode)
I've seen people mention TLC5940s. Would these be something to look into for large groups of LEDs like this one?
For the curious my sketch looks like this:
/* muxProg v1.0
* Author: Johnny Ferguson
* Uses a 4051 to make a simple programmable LED Array
#define PROG_LENGTH 98
// Global Vars
/// Pinout
int ledOut = 13; // led output
int selA = 12; // select A
int selB = 11; // select B
int selC = 10; // select C
/// Select
int bin [] = {000, 1, 10, 11, 100, 101, 110, 111}; // binary values for mux select
int selValue = 0; // holds the value for select bit bitshifting
int sa, sb, sc = 0;
int ledVal = 0;
int portBOut = 0; // pins 8-13
unsigned int pattern [PROG_LENGTH] = {
B00000001,
B00000011,
B00000111,
B00001111,
B00011111,
B00111111,
B01111111,
B11111111,
B11111110,
B11111100,
B11111000,
B11110000,
B11100000,
B11000000,
B10000000,
B00000000,
B10000000,
B11000000,
B11100000,
B11110000,
B11111000,
B11111100,
B11111110,
B11111111,
B01111111,
B00111111,
B00011111,
B00001111,
B00000111,
B00000011,
B00000001,
B00000000,
B00000001,
B00000011,
B00000111,
B00001111,
B00011111,
B00111111,
B01111111,
B11111111,
B11111110,
B11111100,
B11111000,
B11110000,
B11100000,
B11000000,
B10000000,
B00000000,
B10000000,
B11000000,
B11100000,
B11110000,
B11111000,
B11111100,
B11111110,
B11111111,
B01111111,
B00111111,
B00011111,
B00001111,
B00000111,
B00000011,
B00000001,
B00000000,
B00000000,
B00000000,
B11111111,
B11111111,
B00000000,
B00000000,
B11111111,
B11111111,
B00000000,
B00000000,
B11111111,
B11111111,
B11111111,
B11111111,
B00000000,
B00000000,
B00000000,
B00000000,
B11111111,
B11111111,
B00000000,
B00000000,
B11111111,
B11111111,
B00000000,
B00000000,
B11111111,
B11111111,
B11111111,
B11111111,
B00000000,
B00000000,
B00000000,
B00000000,
// setup
void setup(){
// Set pins 10-13 for output
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
// main loop
void loop(){
for(int j = 0; j < PROG_LENGTH; j++){
for(int i = 0; i < 8; i++){
// load selValue from binary array
selValue = bin[i];
// bitshift and mask to get appropriate values
sa = selValue & 0x01;
sb = (selValue >> 1) & 0x01;
sc = (selValue >> 2) & 0x01;
// get the on/off bit for this part of the pattern, then use port manipulation to write select values (faster than digitalwrite)
ledVal = ((pattern[j] >> i) & 0x01) ? 1 : 0;
portBOut = B00111100 & ((ledVal << 5) | (sa << 4) | (sb << 3) | (sc << 2));
PORTB = portBOut;
// to stop the animation from playing way too fast
delay(1);
// stops the last LED in the chain from staying on bright between animation frames
PORTB = B00000000;
delay(1);
I'm thinking for the next sketch I do with this board, I'll write the program so my array can specify a time in milliseconds for each frame to display. I'd also like to avoid the use of delay as it's just sloppy in general (but was a great way to get this thing tested).
