Dimmer drawing power, or not?
I talked to a guy who once had a particular dimmer for the down-lights in his living room. Unfortunately he had to replace it because it didn't manage to draw enough power for the lights. It's a triac dimmer, and we have 230 AC here at 60 Hz where we live. Now I have a few questions regarding that:
  1. By my understanding, the dimmer itself doesn't draw much current; rather, it's the bulbs (load) that draws current through the dimmer (triac and resistors). Correct?
  2. Very often a standard household dimmer tops out around 10 amp, right?
  3. If this dimmer reached it's breaking point at 10 amp, it would be weird, as 9 (for example) down-lights don't draw that much current. Yes?
  4. Having a regular household dimmer taking more than 15 amp is usually not necessary?
  5. Are fuses usually built into such dimmers, so that if they reach high currents they won't get warmer than they are supposed to get?
  6. For very basic household dimmers, only some resistors, a triac and an optocoupler are in metallic contact with the mains current. Correct?
HI,
I'm stuck at
it didn't manage to draw enough power for the lights....
I'm not sure what that means. As you mentioned, the dimmer doesn't draw power, it only throttles it by only turning on during part of the 60Hz cycle.
Could this be an issue with an older dimmer with a new LED lamp?
Some dimmers are "not happy" with low power loads... A little night-light may not dim properly. Some LED light bulbs are not dimmable, or they may not draw enough power for the dimmer to work properly. Most fluorescent bulbs don't work with a regular dimmer either.
Also, the dimmable LED may not follow the same dimming-curve... My girlfriend has 3 regular 75W incandescent floods, plus one "equivalent" LED on the same circuit. With dimmer at minimum the incandescent lights are barely glowing and the LED is quite a bit brighter, but it is definitely dim. (This is an Insteon home automation dimmer and it dims in "steps", 16 steps I think, so there is a minimum before it goes completely off.)
Correct. The TRIAC [u]switches on & off twice per cycle[/u] (when it's dimming) so theoretically, it's just like a light switch turning on & off very-quickly without using any power itself. However it's not 100% efficient and that's why they sometimes get warm.
So, it's wasting a little power but you're still not using as much power as the light at full-brightness. ...But in the winter the heat energy isn't wasted because helps to warm your house, taking a tiny-tiny load off your heater. :wink: It the summer your air conditioning (if you have AC) has to work a tiny-tiny bit harder so the energy is double-wasted.
  1. Very often a standard household dimmer tops out around 10 amp, right?
I'd say usually less. Here in the U.S. most of them are rated at about 600W. (about 5 Amps at 120V).
  1. If this dimmer reached it's breaking point at 10 amp, it would be weird, as 9 (for example) down-lights don't draw that much current. Yes?
It's probably going to burn-up. Semiconductors tend to die by shorting-out, so it might just stay-on at full-brightness.
  1. Having a regular household dimmer taking more than 15 amp is usually not necessary?
It depends on the load. I've only seen Wattage ratings. Current = Wattage/Voltage. 15A at 230V is 3450W so that would be an "industrial application". What's your 230V circuit rated for? Here in the U.S., we usually have 15 or 20A circuit breakers.
  1. Are fuses usually built into such dimmers, so that if they reach high currents they won't get warmer than they are supposed to get?
Probably not a regular fuse. There might be a thermal fuse. I've seen heaters & hair driers with a thermal fuse... If the fan stops working or the airflow otherwise stops the thermal fuse blows. In any case, if it's a "legitimate" dimmer with the required safety/regulatory approvals it shouldn't fail in a way that starts a fire, even if you overload it.
  1. For very basic household dimmers, only some resistors, a triac and an optocoupler are in metallic contact with the mains current. Correct?
Usually everything (except the grounded case) is connected to the power line.... Nothing is isolated (except the case).
If you build a dimmer with "wires coming out" for connection to the Arduino, the external low-voltage connections must be isolated. An "Arduino light dimmer" usually has TWO opto-isolators - One for the TRIAC-trigger and one for the phase detection. When I built a microcontroller dimmer I used the transformer from the power supply I built to isolate the phase detection.
JohnRob:
HI,
I'm stuck at
Exactly! :slight_smile: It didn't make sense to me either. Seems like I didn't misunderstand this at all. I don't think the dimmer was very old, but I'm not sure, and I don't think it's due to the lamps.
I got very relieved by reading your answers, as I wasn't way off (that would be terrible). So, this is the story behind the post: I am currently building a touch controlled dimmer (capacitive sensors). The guy I was talking to about this is actually my uncle, who is an electronics engineer. He told me about one of his dimmers once that he had to switch. When I asked him about this, he said it drew too little power. Maybe he just meant the lights drew too little, and that the dimmer couldn't handle it. At least that's the only thing that makes sense, when I think about it.
The reason I asked so much about current through these dimmers, is just to get a sense of how much current I need to design the high current circuit for (trace width). I might need some help with the circuit to make sure I'm doing this optimally, but it might be better to do that in another thread, or even another forum if this is not the right one. I haven't used this forum that much. Thanks again! :slight_smile:
The problem with low current relates to simple two-wire dimmers which are in series with the lamp. If the load has two high a resistance, or - as with LEDs - has a threshold voltage before it conducts at all, the dimmer does not "see" the AC waveform correctly and cannot determine when in the cycle to fire. There may also be problems with the minimum current the Triac requires to latch ON.
PelleS:
That is determined by how much current the load requires. Just divide the specified load wattage by the voltage.
