I am using a ZCD circuit controlling a TRIAC. Now I am using Dimmer library for this purpose. It works fine with ATMega 328 but whenever I try to upload the code in ATMega 128 using Arduino IDE this error pops up:
Arduino: 1.8.4 (Windows 10), Board: "ATmega128, 2.7v, Disabled (default), 16 MHz external"
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp: In member function 'void Dimmer::begin(uint8_t, bool)':
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:15:20: error: 'TCCR2A' was not declared in this scope
#define _TCCRxA(X) TCCR ## X ## A
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:16:19: note: in expansion of macro '_TCCRxA'
#define TCCRxA(X) _TCCRxA(X)
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:157:5: note: in expansion of macro 'TCCRxA'
TCCRxA(DIMMER_TIMER) = TCCRxA_VALUE; // Timer config byte A
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:17:20: error: 'TCCR2B' was not declared in this scope
#define _TCCRxB(X) TCCR ## X ## B
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:18:19: note: in expansion of macro '_TCCRxB'
#define TCCRxB(X) _TCCRxB(X)
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:158:5: note: in expansion of macro 'TCCRxB'
TCCRxB(DIMMER_TIMER) = TCCRxB_VALUE; // Timer config byte B
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:19:20: error: 'TIMSK2' was not declared in this scope
#define _TIMSKx(X) TIMSK ## X
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:20:19: note: in expansion of macro '_TIMSKx'
#define TIMSKx(X) _TIMSKx(X)
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:159:5: note: in expansion of macro 'TIMSKx'
TIMSKx(DIMMER_TIMER) = 0x02; // Timer Compare Match Interrupt Enable
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:21:19: error: 'OCR2A' was not declared in this scope
#define _OCRxA(X) OCR ## X ## A
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:22:18: note: in expansion of macro '_OCRxA'
#define OCRxA(X) _OCRxA(X)
C:\Program Files (x86)\Arduino\libraries\Dimmer-master\src\Dimmer.cpp:160:5: note: in expansion of macro 'OCRxA'
OCRxA(DIMMER_TIMER) = 100 * 60 / acFreq - 1; // Compare value (frequency adjusted)
exit status 1
Error compiling for board ATmega128.
option enabled in File -> Preferences.
