Hi I have a dimmer to design in certain way. I know basic and done some sketch.
if ( MODE == 2) { // DIMM
if (tempc < settemp-2) { //100%
OCR1A = 50;}
if ((tempc >= settemp-2)&&(tempc < settemp-1)) { //75%
for( i = 50; i <= 110; i++) {
OCR1A = i; //set the compare register brightness desired.
delay(5);
if ((tempc >= settemp-1)&&(tempc < settemp)) { //50%
for( i = 110; i <= 220; i++) {
delay(5);
if (tempc >= settemp) { //OFF
for( i = 220; i <= 483; i++) {
delay(5);
That should work like:
if tempc is below 2deg from settemp then light should dimm to certain value (75%) just once! and stays
if tempc is below 1 deg from settemp then light should dimm to 50% brightness just once! and stays
if tempc is = settemp light is OFF
and from that stage when tempc is going to low then should dimm from off to 50% just once
then when it is lower then from 50-75% and when is lower then 2deg fully ON.
any help?
