keef476:
I am just changing the delay values and seeing what happens and it works ok if a little choppy.
The for loop at the beginning decrements from high to low, the other for loop increments from low to high.
The delays inside the for loops stipulate how long to dwell at that analogWrite value before going to the next.
The delay(1000) makes a 1 second delay between the two for loops.
This sketch may result smoother (less choppy) transitions. It does for LEDs, but I don't know how it will go for your ac dimming module :
extern const uint8_t gamma[];
int led = 3; // the PWM pin the LED is attached to
int brightness; // how bright the LED is
int corrected;
int dwell;
pinMode(led, OUTPUT);
dwell = 500;
for (brightness = 20; brightness < 240; brightness ++)
corrected = pgm_read_byte(&gamma[brightness]);
analogWrite(led, corrected);
delay(dwell);
for (brightness = 240; brightness > 20; brightness --)
delay(dwell);
const uint8_t PROGMEM gamma[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255};
