I have to set the brightness of my nextion NX3224TO24, interfaced to the ESP8266 serial port. What is the command to set the dim variable with or without a library?
I answer myself:
Serial.print("dim=25");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
dim
dims Nextion
Backlight dim=32, dims=100
Sets the backlight level in percent
min 0, max 100, default 100 or user defined
Note: dim=32 will set the current backlight level to 32%.
using dims=32 will set the current backlight level to 32% and save this to be new power on default backlight level, persisting until changed.
skandy63:
I answer myself:Serial.print("dim=25");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
That's right.
You have answer your self
please allow me
Serial.print("\xFF\xFF\xFF");
and you write only 2 lines
