Dimming ZXLD1366 LED Driver via PWM
I want to dim my LED and have a LED driver based on the ZXLD1366 IC.
The PWM input voltage of this IC is max 2.5V according to it's datasheet: http://www.diodes.com/datasheets/ZXLD1366.pdf
Now I thought "that's okay, as long as I don't set PWM above 60 (which should be around the 2.5V) all will be okay". Well: It wasn't okay and the IC blew :( =(
What did I do wrong and how exactly will I be able to use PWM with this IC?
Thanks for your help :)
Cherubim: The PWM input voltage of this IC is max 2.5V
Where does it say this?
In the datasheet :) VADJ 0.3 -2.5V
OK,
So the datasheet says:
Maximum ratings: Vadj = -0.3 - 6VDC.
It also says:
ADJ: Drive with DC Voltage 0.3 < Vadj < 2.5 to adjust from 25% to 200%., with normal operation at 1.25V.
So, I would interpret that as you want to be operating at 1.25V, unless you have a reason to do otherwise. If you were operating at 5V, 60% duty cycle, you’re at 3V, which it’s not going to like.
Exactly - I already found out the hard way that the IC doesn't like too much voltage :)
Does that mean your original questions have now been answered?
No, not at all. I know that I need to have max 2.5V - but I don't know how to get there.
arduinodlb:
It also says:
Variable voltage? That doesn’t sound like a PWM input to me. I think the PWM input is the other pin…
Well the datasheet says otherwise :)
"Enhanced output current dimming resolution can be achieved by applying a PWM signal to the ‘ADJ’ pin. " "Single pin on/off and brightness control using DC voltage or PWM "
So it is a combined pin.
Cherubim:
Well the datasheet says otherwise :slight_smile:
PWM "
Oh, I see.
It says "PWM frequency < 300Hz PWM amplitude = VREF Measured on ADJ pin "
So you need a voltage divider to drop 5V down to whatever reference voltage you want.
PS: Arduino PWM frequency is higher then 300Hz so that’s another problem you need to solve.
Cherubim:
No, not at all. I know that I need to have max 2.5V - but I don’t know how to get there.
In this case, it means either a DC voltage of 2.5V Max, or an average PWM voltage of 2.5V Max. This is how you get there:
arduinodlb:
It also says:
So, for your 5V supply, you want a duty cycle of 1.25/5 = 25%. This will provide an AVERAGE voltage of 1.25V, which is less than the 2.5V MAX.
arduinodlb: So, for your 5V supply, you want a duty cycle of 1.25/5 = 25%. This will provide an AVERAGE voltage of 1.25V, which is less than the 2.5V MAX.
No. The datasheet specifically says the PWM amplitude must be Vref.
fungus:
Hmmm. You're right. That seems odd.
Thanks for your posts. As you see, this isn't an easy matter - at least when you only know the basic electronics stuff like me :( I can programm my arduino, but when it comes to things like that, I'm overchallenged.
arduinodlb:
fungus: No. The datasheet specifically says the PWM amplitude must be Vref.
There's nothing "odd" about it. It was probably a case of do it that way or add more pins to the chip.
You can set the PWM amplitude with two resistors. No big deal.
fungus:
arduinodlb:
fungus:
Hmmm. You’re right. That seems odd.
There’s nothing “odd” about it.
Well, that’s a matter of opinion.
I'm now successfully using a BC547 transistor with a 4k7 Ohm base resistor to dim the LEDs. This is working perfectly fine, with 122Hz timers or the default 490Hz ones.
