after SPI-Mode does not work, i tryed with 4bit and Liquidcrystal...and i get a text-output...first thank you for the lib
here the Data-Sheet of the display:
the example shows:
"hello, world!" in the first line - OK
"!" in the second line - FALSE (copy of line 1 cols >12 in line 2)
in the 3rd line
i changed the row-offsets in LiquidCrystal.cpp see thread - same result
note that only 12 cols are accessable
col 13 [!] and following is printed also on line 2
i looked also in hardware/arduino/cores/arduino/print.cpp for the print-function (but this only uses write in a loop), and its not overwritten in LiquidCrystal.cpp/h
the library only supports 2-line-mode...
i added
#define LCD_4LINE 0x09 to LiquidCrystal.h and the following to the begin-method in the cpp:
if (lines == 4) {
_displayfunction = LCD_4BITMODE | LCD_4LINE;
} else //now the (if lines >1)
now the display changes contrast (white on black,maybe "inverting cursor"), but why?
i cant still not access the 4 lines.. (2= line 3, 1=no text,3=no text)
i assume that the behaviour is because this display uses a "extended function set" to set number of lines, but i dont get it working yet (LCD_4LINE sets reversebit=inverse display)
RE-bit is set by functionset (DB2=4)
regards Frank
