am trying to get GPS data gained from adafruits ultimate GPS logger shield to display on a screen this is the screen
since they both use software serial i expected to just be able to print out the gps commands straight to the something like this
LCD.print(examplegpsdatafunction());
However when i do this just a number is shown on the display not relevant to the actual data, i have checked to see if it was the screen but it is not as it accepts other basic functions as input and printing gps functions to the serial console also works so i am confused what i need to do to get this to work below i have put the full code
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#define txPin2 2
static const int RXPin = 8, TXPin = 7;
static const uint32_t GPSBaud = 9600;
int gettime = 0;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
SoftwareSerial LCD = SoftwareSerial(0, txPin2);
const int LCDdelay=10;
void lcdPosition(int row, int col) {
LCD.write(0xFE); //command flag
LCD.write((col + row*64 + 128)); //position
delay(LCDdelay);
void clearLCD(){
LCD.write(0x01); //clear command.
delay(LCDdelay);
void backlightOn() { //turns on the backlight
LCD.write(0x7C); //command flag for backlight stuff
LCD.write(157); //light level.
delay(LCDdelay);
void backlightOff(){ //turns off the backlight
LCD.write(128); //light level for off.
delay(LCDdelay);
void serCommand(){ //a general function to call the command flag for issuing all other commands
LCD.write(0xFE);
pinMode(txPin2, OUTPUT);
LCD.begin(9600);
ss.begin(GPSBaud);
backlightOn() ;
clearLCD();
lcdPosition(0,0);
Serial.println(F("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum"));
Serial.println(F(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail"));
Serial.println(F("---------------------------------------------------------------------------------------------------------------------------------------"));
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
printInt(gps.satellites.value(), gps.satellites.isValid(), 5);
printInt(gps.hdop.value(), gps.hdop.isValid(), 5);
printFloat(gps.location.lat(), gps.location.isValid(), 11, 6);
printFloat(gps.location.lng(), gps.location.isValid(), 12, 6);
printInt(gps.location.age(), gps.location.isValid(), 5);
printDateTime(gps.date, gps.time);
printFloat(gps.altitude.meters(), gps.altitude.isValid(), 7, 2);
printFloat(gps.course.deg(), gps.course.isValid(), 7, 2);
printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2);
printStr(gps.course.isValid() ? TinyGPSPlus::cardinal(gps.course.value()) : "*** ", 6);
//String dt = d.date;
unsigned long distanceKmToLondon =
(unsigned long)TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON) / 1000;
printInt(distanceKmToLondon, gps.location.isValid(), 9);
double courseToLondon =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
printFloat(courseToLondon, gps.location.isValid(), 7, 2);
const char *cardinalToLondon = TinyGPSPlus::cardinal(courseToLondon);
printStr(gps.location.isValid() ? cardinalToLondon : "*** ", 6);
printInt(gps.charsProcessed(), true, 6);
printInt(gps.sentencesWithFix(), true, 10);
printInt(gps.failedChecksum(), true, 9);
Serial.println(gps.time.value());
Serial.println(gps.location.lat(), 6);
Serial.println(gps.hdop.value());
smartDelay(1000);
//gettime = Serial.println(gps.time.value());
// this is the key problem
LCD.print(gps.time.value());
delay(6000);
clearLCD();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec)
if (!valid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartDelay(0);
static void printInt(unsigned long val, bool valid, int len)
char sz[32] = "*****************";
if (valid)
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
smartDelay(0);
static void printDateTime(TinyGPSDate &d, TinyGPSTime &t)
if (!d.isValid())
Serial.print(F("********** "));
char sz[32];
sprintf(sz, "%02d/%02d/%02d ", d.month(), d.day(), d.year());
Serial.print(sz);
if (!t.isValid())
Serial.print(F("******** "));
char sz[32];
sprintf(sz, "%02d:%02d:%02d ", t.hour(), t.minute(), t.second());
Serial.print(sz);
printInt(d.age(), d.isValid(), 5);
smartDelay(0);
static void printStr(const char *str, int len)
int slen = strlen(str);
for (int i=0; i<len; ++i)
Serial.print(i<slen ? str[i] : ' ');
smartDelay(0);
gpsandscreen.ino (5.08 KB)
