Direct communication using Visual Studio (no setup() and loop() wrapping)
I am currently building a 3D scanner and I just bought an Arduino Uno with a Big Easy Driver to control a stepper motor (for the scanner’s rotating plate) and everything is working fine. However, I realized that I would need a way to communicate directly with the device (just like any other serial peripheral out there). Ideally, I would need to do this in real time (without uploading the code) because what I want to achieve is drive the stepper one pulse, take a capture (with my camera), process the information and repeat. In other words, I want the Arduino part to be a “module” in my main C++ program (which will contains some OpenCV for image capture and processing). I am using Visual Studio 2013. How could I do that? Thanks!
Your only option is to write a PC program that "talks" to your Arduino and an Arduino program that "talks" to the PC program.
This Python-Arduino demo illustrates the idea. The same general approach is applicable in other languages.
...R
Serial communication with the Arduino is hardly "direct communication".
The Arduino is able to read, process, and act on, serial data in real time.
I want the Arduino part to be a "module" in my main C++ program
Modules are software. The Arduino is hardware. Your asking for an elephant to be a suitable substitute for a Rum and Coke.
if you are looking for sending Arduino's sensor data to a mysql database on Windows PC i recommend MysqlIO app for windows
