Direct drive 8x8 matrix does not work
I followed this Arduino Playground - DirectDriveLEDMatrix exactly did the codes to get frequency timer2 to compile correctly and wired up the matrix exactly the same and i get nothing.... i upload the code to the Duemilanove and it just sits there the display does nothing.
You must have it wired up wrong.
I have used that code, as have many others, and it works.
LED matricies are often a major pain to wire up, both the home-made and pre-built varieties.
It is very easy to get the pin numbering of pre-made matricies wrong. You need to check the datasheet to find which pin corresponds to which row/column. It will definitely NOT be row 1 = pin 1.
Indeed, there is no standard pinouts from LED Matrix and each manufacturer seems to decide which pin goes to which column/row, just by throwing a dice. Read the datasheet and rejig your wires to match whatever schematic you are using.
