Direct pin manipulation on pin 12?
Hello all, Does anyone out here know why direct pin manipulation works fine on pin 4:
void setup(){
  pinMode(4, OUTPUT);
void loop(){
  PORTD |= _BV(4);
  PORTD &= ~_BV(4);
But on pin 12 with PORTD changed to PORTB it does not work:
void setup(){
  pinMode(12, OUTPUT);
void loop(){
  PORTB |= _BV(12);
  PORTB &= ~_BV(12);
As I understand from: http://www.arduino.cc/playground/Learning/PortManipulation PORTB should be the register for pin 12.
What am I doing wrong? Thanks for the help!
Hmm never mind. For pin 12 it is:
"void setup(){
void loop(){
  PORTB |= _BV(4);
  PORTB &= ~_BV(4);
As in pins_arduino.c it says:
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
    _BV(0), /* 0, port D */
    _BV(1),
    _BV(2),
    _BV(3),
    _BV(4),
    _BV(5),
    _BV(6),
    _BV(7),
    _BV(0), /* 8, port B */
    _BV(1),
    _BV(2),
    _BV(3),
    _BV(4),
    _BV(5),
    _BV(0), /* 14, port C */
    _BV(1),
    _BV(2),
    _BV(3),
    _BV(4),
    _BV(5),
Correct. as ports on AVR chips are only 8 bits wide, ( BV(x); ) BV values can only be 0-7.
