direct port code understanding
hello i have this code that controls a ir helicopter with a arduino uno and ir led and i wanted to learn more about how it uses the pins mainly the stuff like TCCR2A &= ~_BV(COM2B1); can someone point me to the right place to understand how to start writing like this?
#include <TimerOne.h>
//comment this out to see the demodulated waveform
//it is useful for debugging purpose.
#define MODULATED 1
const int IR_PIN = 3;
const unsigned long DURATION = 180000l; // 180000l microseconds
const int HEADER_DURATION = 2000;  // 2000 microseconds
const int HIGH_DURATION = 300;  // 380 microseconds
const int ZERO_LOW_DURATION = 300;  // 220 microseconds
const int ONE_LOW_DURATION = 700;  // 600 microseconds
const byte ROTATION_STATIONARY = 63;
const byte FORWARSDS_BACKWARDS_STATIONARY = 63;
const byte CAL_BYTE = 52;
int Throttle, LeftRight, FwdBack;
void sendHeader()
  #ifndef MODULATED
    digitalWrite(IR_PIN, HIGH);
  #else
    TCCR2A |= _BV(COM2B1);
  #endif
  delayMicroseconds(HEADER_DURATION);
  #ifndef MODULATED
    digitalWrite(IR_PIN, LOW);
  #else
  #endif
  #ifndef MODULATED
  #else
  #endif
  delayMicroseconds(HIGH_DURATION);
  #ifndef MODULATED
  #else
  #endif
void sendZero()
  delayMicroseconds(ZERO_LOW_DURATION);
  #ifndef MODULATED
  #else
  #endif
  #ifndef MODULATED
  #else
  #endif
void sendOne()
  delayMicroseconds(ONE_LOW_DURATION);
  #ifndef MODULATED
  #else
  #endif
  #ifndef MODULATED
  #else
  #endif
void sendCommand(int throttle, int leftRight, int forwardBackward)
  byte b;
  sendHeader();
  for (int i = 7; i >=0; i--)
    b = ((ROTATION_STATIONARY + leftRight) & (1 << i)) >> i;
    if (b > 0) sendOne(); else sendZero();
    b = ((FORWARSDS_BACKWARDS_STATIONARY + forwardBackward) & (1 << i)) >> i;
    b = (throttle & (1 << i)) >> i;
    b = (CAL_BYTE & (1 << i)) >> i;
  pinMode(IR_PIN, OUTPUT);
  //setup interrupt interval: 180ms
  Timer1.initialize(DURATION);
  Timer1.attachInterrupt(timerISR);
  //setup PWM: f=38Khz PWM=0.5
  byte v = 8000 / 38;
  TCCR2A = _BV(WGM20);
  TCCR2B = _BV(WGM22) | _BV(CS20);
  OCR2A = v;
  OCR2B = v / 2;
void timerISR()
  //read control values from potentiometers
  Throttle = analogRead(0);
  LeftRight = analogRead(1);
  FwdBack = analogRead(2);
  Throttle = Throttle / 4; //convert to 0 to 255
  LeftRight = LeftRight / 8 - 64; //convert to -64 to 63
  FwdBack = FwdBack / 4 - 128; //convert to -128 to 127
  sendCommand(Throttle/4, LeftRight, FwdBack);
Here is i think all the info you need
thanks
I think this article explained more about how IR works on Arduino. Enjoy!
