Direct reading of a PORTD bit
In the code below if I use digitalRead(6) I can read the logic level on my PortD Pin6. If I use the Led = PORTD & B11000000 statement I do not get bit6 wiggling as I'd expect.
What am I doing wrong?
void setup() { Serial.begin(9600); // prints title with ending line break Serial.println("Setup starting");
// The Data Direction Register of Port D, don't touch the // lower two bits which are serial IO DDRD = DDRD | B00111100 ;
void loop() { int i = 0 ; int iLed = 0 ; while (true) {
// iLed = digitalRead (6) ; iLed = PORTD & B11000000 ; Serial.println("iLed ="); Serial.print(iLed, OCT);
I take it by "wiggling" you mean "toggling" :) ie 1 becomes 0 and 0 becomes 1
You can do this with an AND operation, because only 1 and 1 = 1 , so as soon as you get a 0 in there, the output will always be 0, it will never flip back to 1 again.
You need an XOR operation eg
PORTD ^= BV(5);
Will flip Bit 5
You need to use PIND to read the port, rather than PORTD.
If you just want to toggle the port you can write PIND. The Atmel datasheet says:
Toggling the Pin * Writing a logic one to PINxn toggles the value of PORTxn, independent on the value of DDRxn.* * Note that the SBI instruction can be used to toggle one single bit in a port.*
Hence you can just write a logical one into the desired bit and it will toggle. So you may write
PIND = BV(5);
Cheers, Udo
Aha! Thanks Condemned! PIND instead of PORTD.
Does that stand for Port INput D ?
Yes. (my shortest post ever :slight_smile: )
EDIT: i screwed it: Every Port has 3 Registers: DDRx, PINx and PORTx.
PIN to read, PORT to write, and DDR to clarify the “DataDirection (Register)”
But, as seen in Post before: you can write to PIN, and the Bits which are written to “1” change their state.
Also you can write with a PORTx pin command, and if the pin is in the input mode (via DDRx pin) and it will turn on (if 1) or off (if 0) the internal pull-up for that pin.
Lefty
