Direct wifi connection between phone and uno R4
I have done a few simple apps successfully using MIT App inventor between My Samsung phone Uno Rev 3 using Bluetooth.
Is it possible to do something similar using Wifi? Without the cloud or an external router?
If the answer is no, as I suspect, without knowing much about Wifi, is there a tutorial using Bluetooth on the Uno R4?
you can run a WiFi access point on the ESP32 and the smartphone can connect too it
have a look at esp32-access-point-ap-web-server - you don't have to run a web server any TCP/IP TCP or UDP client/server protocol can be implemented between the AP and phone
also try a web search for uno r4 ble
Are the EPS32 and the Renesas processor on the R4 2 separate entities that can be controlled separately?
Don't have an R4 (yet), and still using IDE 18.19, but...
The IDE should have WiFiS3 examples after installing the board files.
The first example seems to be a tutorial for an access point.
  // by default the local IP address will be 192.168.4.1
  // you can override it with the following:
  WiFi.config(IPAddress(192,48,56,2));
Leo..
Thanks horace and Wawa. I see the R4 wifi example is what I was looking for. I wasn't sure I could forgo the Router between phone <---> R4 and you helped me get past that. The ESP32 access point example is more polished with buttons so I will hack and slash away at them both. I want to add some ADC readings for remote voltage monitoring as well. But that is for another post if I need help with that. Thank you :slightly_smiling_face:
