Hi, I'm trying to make sure my code from my kit is correct and I got this'
/Users/Manu/Desktop/ultrasonic_sensor_bot/ultrasonic_sensor_bot/ultrasonic_sensor_bot.ino: In function 'void loop()':
ultrasonic_sensor_bot:161:26: error: 'directionn' cannot be used as a function
if (directionn(directionn) = 2(backward)
ultrasonic_sensor_bot:161:32: error: 'backward' was not declared in this scope
/Users/Manu/Desktop/ultrasonic_sensor_bot/ultrasonic_sensor_bot/ultrasonic_sensor_bot.ino:161:32: note: suggested alternative: 'back'
back
ultrasonic_sensor_bot:161:40: error: expression cannot be used as a function
ultrasonic_sensor_bot:162:1: error: expected ')' before '{' token
ultrasonic_sensor_bot:190:1: error: expected primary-expression before '}' token
ultrasonic_sensor_bot:191:6: error: redefinition of 'void loop()'
void loop(){
/Users/Manu/Desktop/ultrasonic_sensor_bot/ultrasonic_sensor_bot/ultrasonic_sensor_bot.ino:157:6: note: 'void loop()' previously defined here
Using library Servo at version 1.1.8 in folder: /private/var/folders/tb/hv2dzdtd7d369mhll7nnghc00000gn/T/AppTranslocation/28444A2D-D710-4A8A-81BD-8E3C7A492B51/d/Arduino.app/Contents/Java/libraries/Servo
exit status 1
how do i fix this?
full code
L=left
R=right
F=forward
B=backward
#include <Servo.h>
int pinLB=6; // define 6 pin left backward
int pinLF=9; //define 9 pin left forward
int pinRB=3; // define 10 pin right backward
int pinRF=5; // define 11 pin right forward
int inputPin = A0; // define ultrasonic signal receiving pin
int outputPin = A1; // define ultrasonic signal transmission pin
int Fspeedd = 0; // forward speed
int Rspeedd = 0; // turning right speed
int Lspeedd = 0; // turning left speed
int directionn = 0; // forward=8 backward=2 left=4 right=6
Servo myservo; // set myservo
int delay_time = 250; // stabilizing time of servo motor after turning
int Fgo = 8; // forward
int Rgo = 6; // turn right
int Lgo = 4; // turn left
int Bgo = 2; // backward
int direction;
Serial.begin(9600); // define motor output pin
pinMode(pinLB,OUTPUT); // pin 8 (PWM)
pinMode(pinLF,OUTPUT); // pin 9 (PWM)
pinMode(pinRB,OUTPUT); // pin 10 (PWM)
pinMode(pinRF,OUTPUT); // pin 11 (PWM)
pinMode(inputPin,INPUT); // define ultrasonic input pin
pinMode(outputPin,OUTPUT); // define ultrasonic output pin
myservo.attach(11); //define the fifth pin of servo motor(PWM)
void advance(int a) // forward
digitalWrite(pinRB,LOW); // let motor act(right back)
digitalWrite(pinRF,HIGH);
digitalWrite(pinLB,LOW); // let motor act(left back)
digitalWrite(pinLF,HIGH); delay(a * 100); }
void right(int b) //turn right(single wheel)
digitalWrite(pinRB,LOW); //let motor act(right back)
digitalWrite(pinLB,HIGH);
digitalWrite(pinLF,HIGH); delay(b
* 100);
void left(int c) //turn left(single wheel)
{ digitalWrite(pinRB,HIGH);
digitalWrite(pinLB,LOW);//let motor act(left back)
delay(c * 100); }
void turnR(int d) //turn right(double wheel)
digitalWrite(pinLF,LOW); //let motor act(left front)
delay(d * 100); }
void turnL(int e) //turn left(double wheel)
digitalWrite(pinRF,LOW);//let motor act(right front)
delay(e * 100); }
void stopp(int f) //stop
delay(f * 100); }
void back(int g) //backward
digitalWrite(pinRB,HIGH); //let motor act(right back)
digitalWrite(pinLB,HIGH);//let motor act(left back)
delay(g * 100); }
void ask_pin_F() // measure distance ahead
myservo.write(90);
digitalWrite(outputPin, LOW); // let ultrasonic transmit low voltage 2μs
delayMicroseconds(2);
digitalWrite(outputPin, HIGH); // let ultrasonic transmit hight voltage 10μs, at least 10μs here
delayMicroseconds(10);
digitalWrite(outputPin, LOW); // keep ultrasonic transmitting low voltage
float Fdistance = pulseIn(inputPin, HIGH); // read time gap
Fdistance=Fdistance/5.8/10; // convert time into distance(unit:cm)
Serial.print(" F distance "); //output distance(unit:cm)
Serial.println(Fdistance); //display distance
Fspeedd = Fdistance; // read distance into Fspeedd(forward speed)
void ask_pin_L() // measure distance on the left side
{ myservo.write(5);
delay(delay_time);
float Ldistance = pulseIn(inputPin, HIGH); // read time gap Ldistance=
Ldistance/5.8/10; // convert time into distance(unit:cm)
Serial.print(" L distance "); //output distance(unit:cm)
Serial.println(Ldistance); //display distance
Lspeedd = Ldistance; // read distance into Lspeedd(Leftward speed)
void ask_pin_R() // measure distance on the right side
myservo.write(177); delay(delay_time);
digitalWrite(outputPin, HIGH); // let ultrasonic transmit high voltage 10μs, at least 10μs here
float Rdistance = pulseIn(inputPin, HIGH); // read time gap
Rdistance=Rdistance/5.8/10; // convert time into distance(unit:cm)
Serial.print(" R distance "); //output distance(unit:cm)
Serial.println(Rdistance); //display distance
Rspeedd = Rdistance; // read distance into Rspeedd(rightward speed)
void detection() //measure three angles(0.90.179)
ask_pin_F(); // read distance ahead
if(Fspeedd < 10) // if distance ahead is less than 10cm
stopp(1); // Clear output data back(2);
// backward for 0.2 sec
if(Fspeedd < 25) // if distance ahead is less than 25cm
ask_pin_L(); // read distance on the left side
delay(delay_time); // wait for the servo to stabilize
ask_pin_R(); //read distance on the right side
if(Lspeedd > Rspeedd) //if the distance on the left side is larger than that of the right side
directionn = Rgo; //go rightwards
if(Lspeedd <= Rspeedd); //if the distance on the left side is no more than that of the right side
directionn = Lgo; //go leftwards
if (Lspeedd < 10 && Rspeedd < 10) //if the distance on both sides is less than 10cm
directionn = Bgo; //go backwards
else //if the distance ahead if no less than 25cm
directionn = Fgo; //go forward
myservo.write(90); //let servo motor return to its ready position, prepared for the next measurement
detection(); //measure angle and decide moving direction
if (directionn == 2)
if (directionn(direction) = 2(backward)
back(8); // backward(car)
turnL(2); //slightly move leftwards(prevent from being stuck in blind alley)
Serial.print(" Reverse ");
display direction(backward)
if (directionn == 6)
if (directionn(direction) = 6(rightward)
{ back(1);
turnR(6); // turn right
Serial.print(" Right ");
display direction(turn left)
if (directionn == 4)
if (directionn(direction) = 4(turn left)
{ back(1);
turnL(6); // turn left
Serial.print(" Left ");
display direction(turn right)
if (directionn == 8)
if (directionn(direction) = 8(forward)
advance(1); // go forward as normal
Serial.print(" Advance ");
display direction(forward)
Serial.print(" ");
void loop(){
