Using the interrupts(); and noInterrupts(); allows for the interrupts to enabled or disabled. If interrupts are disabled, and an interrupt signal comes in, does the system service the interrupt once interrupts are re-enabled? Or does that interrupt request get lost?
I have a chunk of code that writes data to an external device and do not want an interrupt (timer to send data from external device) to execute unless full records are written.
I dont understand what one of each kind means.
Is this accurate?
ex:
nointerrupts();
//code
//code
//code <--------Interrupt 0 falling edge
//code
//code
interrupts();
//execute ISR for interrupt 0
If there are two or more falling edge 0 interrupts (or any other kind of interrupt), while you have interrupt handling disabled, only the last interrupt (of any given type) will still be pending when interrupts are again enabled.
I gotcha. So basically the arduino can only remember one interrupt while interrupts are disabled and the last interrupt will be the one remembered when they are enabled. Hmmm....is there a way to set priority for triggered interrupts? For example, if INT0 is triggered while interrupts are disabled, it cannot be overwritten if INT1 is triggered later. In other words, INT0 NEEDS to be serviced but INT1 can go without.
Thanks again!
No. From the ATmega data sheet: Quote:
...if one or more interrupt conditions occur while the Global Interrupt
Enable bit is cleared, the corresponding Interrupt Flag(s) will be set
and remembered until the Global Interrupt Enable bit is set, and will
then be executed by order of priority.
@DigitalMagZ
No. Priorities are fixed. Here's the list for the '328p. Highest priority is the first one in the list. Lowest priority is the last.
[*] RESET External Pin, Power-on Reset, Brown-out Reset and Watchdog System Reset
[*] INT0 External Interrupt Request 0
[*] INT1 External Interrupt Request 1
[*] PCINT0 Pin Change Interrupt Request 0
[*] PCINT1 Pin Change Interrupt Request 1
[*] PCINT2 Pin Change Interrupt Request 2
[*] WDT Watchdog Time-out Interrupt
[*] TIMER2 COMPA Timer/Counter2 Compare Match A
[*] TIMER2 COMPB Timer/Counter2 Compare Match B
[*] TIMER2 OVF Timer/Counter2 Overflow
[*] TIMER1 CAPT Timer/Counter1 Capture Event
[*] TIMER1 COMPA Timer/Counter1 Compare Match A
[*] TIMER1 COMPB Timer/Coutner1 Compare Match B
[*] TIMER1 OVF Timer/Counter1 Overflow
[*] TIMER0 COMPA Timer/Counter0 Compare Match A
[*] TIMER0 COMPB Timer/Counter0 Compare Match B
[*] TIMER0 OVF Timer/Counter0 Overflow
[*] SPI STC SPI Serial Transfer Complete
[*] USART RX USART Rx Complete
[*] USART UDRE USART Data Register Empty
[*] USART TX USART Tx Complete
[*] ADC ADC Conversion Complete
[*] EE READY EEPROM Ready
[*] ANALOG COMP Analog Comparator
[*] TWI 2-wire Serial Interface
[*] SPM READY Store Program Memory Ready
What PaulS and deSilva are getting at is this: If two interrupts of the same type occur, it doesn't keep count of them. So, if two INT0 events occur while interrupts are disabled, then when interrupts are enabled again, the INT0 service routine will be executed once, not twice.
Other interrupt flags are not inhibited (or affected in any way) by the INT0 flag, so after the INT0 interrupt is serviced, the others will be serviced in order of their respective priorities.
Also I think a lot of sketch examples posted around here using interrupts where the ISR changes the value of a globle variable do not protect the globle variable if a int or long (or other multi-byte) variable is being used. The interrupts() / noInterrupts() are important functions to use if wanting to avoid very hard to troubleshoot problems. Atomic and non-atomic operations should be understood if one is going to write their own ISR functions.
