As mentioned in the datasheet of the ATTiny85 on page 35 I would like to disable Brown-Out-Detection when going to sleep (Power Down) on my ATTiny85. Therefore I'm using the code from Jack here
But my current consumption is still 18.7uA which seems for me, that the BOD is still active. When the BOD is disabled I would expect anything below 1uA...
The date code on my ATTiny85 says 1614 - so it should be pretty new.
Has anyone ever archived to disable the BOD by software on an ATTiny85?? I couldn't find any "evidence" on the internet... Or even better, if you have an ATTiny85, could you please verify if the code from Jack above runs with low power consumption?
Btw: I have enabled BOD at 2.7v in my fuse settings.
I'm using a uCurrent Gold to measure the power consumption.
Here is the full code
#include <avr/sleep.h>
#include <avr/interrupt.h>
#define BODS 7 //BOD Sleep bit in MCUCR
#define BODSE 2 //BOD Sleep enable bit in MCUCR
uint8_t mcucr1, mcucr2;
void goToSleep(void) {
GIMSK |= _BV(INT0); //enable INT0
MCUCR &= ~(_BV(ISC01) | _BV(ISC00)); //INT0 on low level
ACSR |= _BV(ACD); //disable the analog comparator
ADCSRA &= ~_BV(ADEN); //disable ADC
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
//turn off the brown-out detector.
//must have an ATtiny45 or ATtiny85 rev C or later for software to be able to disable the BOD.
//current while sleeping will be <0.5uA if BOD is disabled, <25uA if not.
cli();
mcucr1 = MCUCR | _BV(BODS) | _BV(BODSE); //turn off the brown-out detector
mcucr2 = mcucr1 & ~_BV(BODSE);
MCUCR = mcucr1;
MCUCR = mcucr2;
sei(); //ensure interrupts enabled so we can wake up again
sleep_cpu(); //go to sleep
cli(); //wake up here, disable interrupts
GIMSK = 0x00; //disable INT0
sleep_disable();
sei(); //enable interrupts again (but INT0 is disabled from above)
goToSleep();
Yes, I saw that limitation. I don't know how to find out the revision of the chip. I searched for hours how to interpret the labels on the IC, nevertheless I couldn't find out. The datasheet was modified around 2008 with the section about software BOD disable and my Attiny date code is 1614, therefore I assume it should be revision C or even later. But I'm not sure. If you know, how to determine the revision... would be greatly appreciated.
pylon:
The datasheet mentions where you find the revision information. What package format does your ATtiny have?
Your pins are floating and are not in a defined state. What external circuit do you have on your ATtiny? Post the schematic of your setup.
PDIP package.
In power down mode, floating pins do not matter as far as I know. No external circuit, just the bare Attiny85.
If I disable the BOD by fuses I get the expected power consumption of 200nA, therefore it's not an issue how I connected something...
The revision should be on the bottom side of the package.
The external circuit should at least include a decoupling capacitor.
To check if your ATtiny supports software BOD disabling you can try setting the BODS bit as described in the datasheet and just reading it again (within 3 clock cycles). If you read a 1 your Tiny supports the feature, otherwise it doesn't.
