Disable I2C Pull-Up for Nano 33 IoT
Is it possible to disable the standard SDA and SCL (A4 and A5) pullup resistors on the Nano 33 IoT? I have been having difficulty keeping a stable communication between two Nano 33 IoT closely located. Seems to work for a moment then stops. I am wondering if this might work:
pinMode(pin, INPUT)
I am not sure it would work but I doubt it will solve the problem. But you can try it.
The only way is desoldering R13/R14. But I agree with Smajdalf that this probably doesn't help as two 4k7 pull-ups result in a 2.35kΩ pull-up resistor which is within the limits for a 3V3 system.
I'm missing the usual wiring diagram and code used!
