Disable output at end of code using a timer
I have been working on this code for a while, hoping whatever I am missing is simple. Basically what I want to do is when I turn on my car, it turns on an output unless the car is moving of which it then disables the output. I pretty much got this far without much issue but now I want to add to the code and when the car is turned off, the output is enabled (High) for 20min then goes off (Low) and stays there until the car turns on again. See code below. The last part in bold I know is wrong but I can't figure out what should be here to achieve the last step. Thanks
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
int switchState = 0;
Adafruit_MPU6050 mpu;
void setup(void) {
  // Try to initialize!
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
  Serial.println("MPU6050 Found!");
  // set accelerometer range to +-8G
  mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
  // set gyro range to +- 500 deg/s
  mpu.setGyroRange(MPU6050_RANGE_500_DEG);
  // set filter bandwidth to 21 Hz
  mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
  delay(100);
  pinMode(13, OUTPUT);
  pinMode(2, INPUT);
  /* Get new sensor events with the readings */
  sensors_event_t a, g, temp;
  mpu.getEvent(&a, &g, &temp);
  /* Print out the values */
  Serial.print("Acceleration X: ");
  Serial.print(a.acceleration.x);
  Serial.print(", Y: ");
  Serial.print(a.acceleration.y);
  Serial.print(", Z: ");
  Serial.print(a.acceleration.z);
  Serial.println(" m/s^2");
  Serial.print("Rotation X: ");
  Serial.print(g.gyro.x);
  Serial.print(g.gyro.y);
  Serial.print(g.gyro.z);
  Serial.println(" rad/s");
  Serial.print("Temperature: ");
  Serial.print(temp.temperature);
  Serial.println(" degC");
  Serial.println("");
switchState = digitalRead(2);
if (switchState == LOW){    //Initiates program when car ignition is on
} else if(abs(a.acceleration.x) + abs(a.acceleration.y) + abs(a.acceleration.z) > 13.0){
    digitalWrite(13, LOW); //If car is moving, disables Pin 13 turning off light
  }else{
    digitalWrite(13, HIGH); //If car is not moving, enables Pin 13 turning on light
**if (switchState == HIGH){ //My attempt to to turn off Pin 13 once ignition is off**
I should say "the last part with ** is wrong" not bold. I thought it was going to bold the entry.
If you're going to do something involving twenty minutes, you will need to use millis to record when you last saw that the ignition was on. Then you can check if it's more than that long ago and turn off.
How is the Arduino is powered, and how is pin 2 determining the car is on or off?
Two of your if/else blocks are empty.
This
is just at the bottom of loop(), where it gets executed every time loop() does. Loop.
So perhaps if you posted the best version of something that worked well, but does not yet have the additional feature you are trying to add, it would be easier to see what you need to do.
Also this
is a bit confusing. What do HIGH and LOW mean when on pin 13? I know lighting the build-in LED, but what is the interpretation?
a7
The Adruino will be powered off of the battery, it doesn't put hardly any current so it can just stay live 24/7. Pin 2 would be connected to a source that is only live when the car is in accessory mode (turned on or running). I haven't diagramed out yet if this will be a relay or what but that is minor at this point.
Yeah, I know, here is the code with this removed.
#include <Wire.h>
void setup(void) {
  if (!mpu.begin()) {
    while (1) {
      delay(10);
  delay(100);
  pinMode(2, INPUT);
  Serial.println("");
  }else{
HIGH = Light On
LOW = Light Off
And something added. :expressionless:
THX, all clear now.
Just to be sure:
  • Car not moving, turns ON -> light goes on.
  • If /when car is moving, light turns off.
  • If car stops moving? Light goes back on? or does it stay off once car has moved?
  • the light comes (or stays) on for 20 minutes after the car turns OFF.
Sry if I could glean this from rereading and reading again your description, but if you can confirm this (or fix it in the same style) it will help. Me anyways.
a7
See above
Thanks I am looking at the millis feature now, trying to figure out how that works.
Updated code. Added the last line and a delay. I thought I could just add the delay here for keeping the light on for 10-20min but using delay in the code is screwing with other parts of it and hangs the code which is a problem because if the switchstate changes while this is processing the delay then it is ignored....so I may use an external delay unless I can figure out how to code for this. Thanks for everyone's help thus far.
#include <Wire.h>
void setup(void) {
  if (!mpu.begin()) {
    while (1) {
      delay(10);
  delay(100);
  pinMode(2, INPUT);
  Serial.println("");
if (switchState == LOW){}    //Initiates program when car ignition is on
   else{digitalWrite(13, HIGH);  //If car is not moving, enables Pin 13 turning on light
if (switchState == HIGH){} //If car ignition is off
  delay(100);
  Serial.println("Print out the values removed for now");
  if (switchState == HIGH)   //If car ignition is on
    if (abs(a.acceleration.x) + abs(a.acceleration.y) + abs(a.acceleration.z) > 13.0)
      digitalWrite(13, LOW);  //If car is moving turn off light
      digitalWrite(13, HIGH);  // If car is not moving turn on light
  if (switchState == LOW)      // If car ignition is off
    delay(100);
I find it easier to read when you aren't including {} empty statements and therefor reverse logic. The above is identical in function to your latest code.
I assume the delay(100); in the "if ignition is off" section is where you tried a delay of 20 minutes.
Your analysis of why this won't work satisfactorily is correct.
HTH
a7
Thanks
It's too late here for me to help more right now. Soon enough ppl are going to be telling you about "state machines", also know as "finite-state machines" or FSMs.
If you want to get a head start, google those terms and poke around a bit. See if you get some inspiration. Don't be intimidated, it is hard only until it is easy. You can look at them in general, or google a bit harder and find dozens of Arduino examples.
I encourage you to stay the course with code. Adding an external delay device might be more in your comfort zone right now, but if you are planning on going any further with programming, this is an ideal and simple case to be solved with an FSM.
Part of it will be getting very specific about the way your system is to respond to all the different conditions that may obtain. Which was why I asked at least one question I could not discern from going over your prose, and why I asked you to verify my understanding of your requirements. Long english descriptions can be, or seem, ambiguous or underspecified. I did, trust me, "see above".
a7
Maybe below pseudo code can get you on the right track
  // variable to remember the last time that a movement was detected
  static uint32_t lastMovementTime;
  // if a movement was detected
  if(movementCondition == true)
    // 'reset' the timer
    lastMovementTime = millis();
  // if no movement detected for someDuration
  if(millis() - lastMovementTime > someDuration)
    // do what needs to be done
I thougt about a finite state machine
compiles, but untested
  https://forum.arduino.cc/t/disable-output-at-end-of-code-using-a-timer/900440
  example for a finite state machine
enum class State {OFF,        // car is closed for longer than n minutes
                  IGNITION,   // ignition on
                  MOVING,     // car moves
                  STOPPED     // car was stopped, timer is running
                 } state;
bool isCarMoving = false;
const byte outputPin = 13;
const byte ignitionPin = A0;
const byte sensorPin = A1; // others might not have a sensor
const uint32_t interval = 1 * 60 * 1000UL; // durance of the nonblocking delay - should be finally 20 * 60 * 1000UL
void setup(void) {
  pinMode(outputPin, OUTPUT);
  pinMode(ignitionPin, INPUT);  // HIGH active
  pinMode(sensorPin, INPUT);    // HIGH active
  switchState = digitalRead(ignitionPin);
  isCarMoving = digitalRead(sensorPin);  // replace this with reading MPU6050
  static State previousState = State::OFF;
  static uint32_t previousMillis = 0;
  switch (state)
    case State::OFF :
      // e.g. blink a security LED here ...
      // otherwise - just do nothing
    case State::IGNITION :
      if (isCarMoving)
        Serial.println(F("unless the car is moving of which it then disables the output."));
        digitalWrite(outputPin, LOW);
        state = State::MOVING;
      if (digitalRead(outputPin) == LOW)
        Serial.println(F("I want to do is when I turn on my car, it turns on an output"));
        digitalWrite(outputPin, HIGH);
    case State::MOVING :
        Serial.println(F("when the car is turned off, the output is enabled (High)"));
        // start timer
        previousMillis = millis();
        state = State::STOPPED;
    case State::STOPPED :
      if (millis() - previousMillis > interval)
        Serial.println(F("for 20min then goes off (Low) and stays there until the car turns on again"));
        state = State::OFF;
This should get you close... In order to speed up loop(), I also removed the delay(500) and only spit out the data every second. You can also adjust the delayTime for testing purposes, unless you like to hang around for 20 minutes :slight_smile:
#include <Wire.h>
const int ignitionPin = 2;
const int outputPin = 13;
const float accTriggerLevel = 13.0;
const unsigned long delayTime = 1000UL * 60 * 20;   // twenty minutes
unsigned long startTime;
enum { CAR_OFF, CAR_IDLE, CAR_MOVING, CAR_STOPPED, CAR_DELAY_OFF };
int state;
void setup(void) {
  if (!mpu.begin()) {
    while (1) {
      delay(10);
  delay(100);
  static unsigned long lastReportTime;
  // only report every second
  if ( millis() - lastReportTime >= 1000 ) {
    lastReportTime = millis();
    Serial.println("");
  float totalAcc = abs(a.acceleration.x) + abs(a.acceleration.y) + abs(a.acceleration.z);
  int ignitionState = digitalRead(ignitionPin);
  switch ( state ) {
    case CAR_OFF:
      // car is off, check to see if it is on and react
      if ( ignitionState == HIGH ) {
        // car is on
        state = CAR_IDLE;
    case CAR_IDLE:
      // car is ON but not moving
      if (totalAcc > accTriggerLevel) {
        state = CAR_MOVING;
      if (ignitionState == LOW ) {
        // car turned off
        state = CAR_OFF;
    case CAR_MOVING:
      if (totalAcc <= accTriggerLevel) {
        // car has stopped
        state = CAR_STOPPED;
    case CAR_STOPPED:
        state = CAR_MOVING;
        // car turned off
        state = CAR_DELAY_OFF;
        startTime = millis();
    case CAR_DELAY_OFF:
      // check timer and, if expired, we are OFF
      if ( millis() - startTime >= delayTime ) {
        state = CAR_OFF;
      if (ignitionState == HIGH) {
        // car turned back on so reset
        state = CAR_OFF;
Remove annoying light goes off before it goes on when you restart the car during CAR_DELAY_OFF…
a7
okay, if you can notice that small of a blink on a corner case...
    case CAR_DELAY_OFF:
        state = CAR_OFF;
        state = CAR_IDLE;
And wokwi.com:
A few minor tweaks, but looking good.
You can click on the accelerometer to simulate motion.
# include <Adafruit_MPU6050.h>
# include <Adafruit_Sensor.h>
# include <Wire.h>
// const unsigned long delayTime = 1000UL * 60 * 20;   // twenty minutes
const unsigned long delayTime = 1000UL * 5;   // five seconds
int state;
void setup(void) {
  if (!mpu.begin()) {
    while (1) {
      delay(10);
  delay(100);
  pinMode(ignitionPin, INPUT_PULLUP);
  if ( millis() - lastReportTime >= 5000 ) {
    Serial.println("");
  switch ( state ) {
  case CAR_OFF:
    // car is on
      state = CAR_IDLE;
    else digitalWrite(outputPin, LOW);
    case CAR_IDLE:
        state = CAR_MOVING;
        // car turned off
    case CAR_MOVING:
        // car has stopped
    case CAR_STOPPED:
        state = CAR_MOVING;
        Serial.println("car moving again");
        // car turned off
      else digitalWrite(outputPin, HIGH);
    case CAR_DELAY_OFF:
        state = CAR_OFF;
        state = CAR_OFF;
Casual testing only…
a7
