Disappearing lcd readings
Hello guys, this is my first time posting and I need help!!
My LCD readings disappear on the display after 20 iteration of my code running. I don't know what is the problem and why it does that?
// include the library code
#include <Wire.h>
#include <thermistor.h>
#include <math.h>
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 20 chars and 4 line display
float therm1val_c;
float therm2val_c;
float therm3val_c;
float therm4val_c;
float therm5val_c;
float therm6val_c;
THERMISTOR therm1val(A0, 10000, 3435, 10000);
THERMISTOR therm2val(A1, 10000, 3435, 10000);
THERMISTOR therm3val(A8, 10000, 3435, 10000); //
THERMISTOR therm4val(A9, 10000, 3435, 10000); //
THERMISTOR therm5val(A10, 10000, 3435, 10000); //
THERMISTOR therm6val(A11, 10000, 3435, 10000); //
float therm1val_f_new = 0.0;
float therm2val_f_new = 0.0;
float therm3val_f_new = 0.0;
float therm4val_f_new = 0.0;
float therm5val_f_new = 0.0;
float therm6val_f_new = 0.0;
float avgtemp1_f= 0.0;
float avgtemp2_f = 0.0;
float avgtemp3_f = 0.0;
float avgtemp4_f = 0.0;
float avgtemp5_f = 0.0;
float avgtemp6_f = 0.0;
float therm1val_f_avg_round;
float therm2val_f_avg_round;
float therm3val_f_avg_round;
float therm4val_f_avg_round;
float therm5val_f_avg_round;
float therm6val_f_avg_round;
float avgpress1= 0.0;
float avgpress2 = 0.0;
float trans1voltage;
float trans2voltage;
float trans1pressure;
float trans2pressure;
float trans1pressure_new = 0.0;
float trans2pressure_new = 0.0;
float trans1pressure_avg_int;
float trans2pressure_avg_int;
char delimiter = '\n';
#define M1 75.0 //slope for suction transducer curve
#define CONST1 37.5 //off set for suction transducer curve
#define PSIA 14.7 //psis to psia conversion
#define M2 163.25
#define CONST2 67.625
//function prototypes
float thermistor_to_temp_f(float thermistor_val);
float rounding_function(float value, int n );
float averagefunction(float &avgtemp, float thermval, float coeff1, float coeff2);
float voltage(float value);
float screen_write(int avg_int, int x, int y, int z);
  lcd.init();  //initialize the lcd
  lcd.backlight();  //open the backlight
  lcd.clear();
  lcd.setCursor (0, 0);
  lcd.print ("Welcome to our lab");
  lcd.setCursor (0, 1);
  lcd.print("unit! Senior class");
  lcd.setCursor (0, 2);
  lcd.print("of 2021");
  delay(2500);
  Serial.print("Discharge");
  Serial.print(",");
  Serial.print("Suction");
  Serial.print(",");
  Serial.print("EWT");
  Serial.print(",");
  Serial.print("LWT");
  Serial.print(",");
  Serial.print("Therm3");
  Serial.print(",");
  Serial.print("Therm4");
  Serial.print(",");
  Serial.print("Therm5");
  Serial.print(",");
  Serial.print("Therm6");
  Serial.print("\n");
  for (int i=0; i<10; i++){ //take 10 samples over the course of 1 second
    //entering water thermistor
  lcd.clear();
  lcd.setCursor (0, 0); // go to the top left corner
  lcd.print("Discharge"); // write this string on the top row
  lcd.setCursor (0, 1);            // go to the 2nd row
  lcd.print("Suction");
  lcd.setCursor (0, 2);            // go to the third row
  lcd.print("EWT");
  lcd.setCursor (0, 3);            // go to the fourth row
  lcd.print("LWT");
  lcd.setCursor (17, 2);
  lcd.print(char(223));
  lcd.print('F');
  lcd.setCursor (17, 3);
  lcd.print('F');
  lcd.setCursor (17, 1);
  lcd.print("PSI");
  lcd.setCursor (17, 0);
  lcd.print("PSI");
    therm1val_c = therm1val.read(); //read thermistor in celsius
    float therm1val_f_avg = averagefunction(avgtemp1_f, thermistor_to_temp_f(therm1val_c), 0.75, 0.25);
    therm1val_f_avg_round = rounding_function(therm1val_f_avg,1);
    //leaving water thermistor
    therm2val_c = therm2val.read(); //read thermistor in celsius
    float therm2val_f_avg = averagefunction(avgtemp2_f, thermistor_to_temp_f(therm2val_c), 0.75, 0.25);
    therm2val_f_avg_round = rounding_function(therm2val_f_avg,1);
    //suction transducer
    trans1voltage = voltage(analogRead(A2)); //gets transducer voltage
    trans1pressure = (M1*trans1voltage) -CONST1 + PSIA; //voltage to psis conversion (offset by 1 atm or 14.7psi). add 14.7 to get psia
    float trans1pressure_avg= averagefunction(avgpress1, trans1pressure, 0.95, 0.05);
    trans1pressure_avg_int= rounding_function(trans1pressure_avg,0);
    //discharge transducer
    trans2voltage = voltage(analogRead(A3)); //gets transducer voltage
    trans2pressure = (M2*trans2voltage) -CONST2; //voltage to psia conversion
    float trans2pressure_avg= averagefunction(avgpress2, trans2pressure, 0.95, 0.05);
    trans2pressure_avg_int= rounding_function(trans2pressure_avg,0);
    delay(100);
if (therm1val_f_new != therm1val_f_avg_round) //compares new value to rounded average value
    therm1val_f_new = screen_write(therm1val_f_avg_round, 11, 2, 15, 1);
  if (therm2val_f_new != therm2val_f_avg_round)
    therm2val_f_new = screen_write(therm2val_f_avg_round, 11, 3, 15, 1);
  if (trans1pressure_new  != trans1pressure_avg_int)
    trans1pressure_new = screen_write(trans1pressure_avg_int, 11, 1, 13, 0);
  if (trans2pressure_new  != trans2pressure_avg_int)
    trans2pressure_new = screen_write(trans2pressure_avg_int, 11, 0, 13, 0);
  delay(2000);
  lcd.clear();
  lcd.print("Therm3"); // write this string on the top row
  lcd.print("Therm4");
  lcd.print("Therm5");
  lcd.print("Therm6");
  lcd.print('F');
  lcd.print('F');
  lcd.print("F");
  lcd.print("F");
    therm3val_c = therm3val.read(); //read thermistor in celsius
    float therm3val_f_avg = averagefunction(avgtemp3_f, thermistor_to_temp_f(therm3val_c), 0.75, 0.25);
    therm3val_f_avg_round = rounding_function(therm3val_f_avg,1);
    //fourth thermistor
    therm4val_c = therm4val.read(); //read thermistor in celsius
    float therm4val_f_avg = averagefunction(avgtemp4_f, thermistor_to_temp_f(therm4val_c), 0.75, 0.25);
    therm4val_f_avg_round = rounding_function(therm4val_f_avg,1);
    //Fifth thermistor
    therm5val_c = therm5val.read(); //read thermistor in celsius
    float therm5val_f_avg = averagefunction(avgtemp5_f, thermistor_to_temp_f(therm5val_c), 0.75, 0.25);
    therm5val_f_avg_round = rounding_function(therm5val_f_avg,1);
    //Sixth thermistor
    therm6val_c = therm6val.read(); //read thermistor in celsius
    float therm6val_f_avg = averagefunction(avgtemp6_f, thermistor_to_temp_f(therm6val_c), 0.75, 0.25);
    therm6val_f_avg_round = rounding_function(therm6val_f_avg,1);
    delay(100);
 if (therm3val_f_new != therm3val_f_avg_round)
    therm3val_f_new = screen_write(therm3val_f_avg_round, 11, 1, 13, 1); // rkm el screen 3
    if (therm4val_f_new != therm4val_f_avg_round)
    therm4val_f_new = screen_write(therm4val_f_avg_round, 11, 0, 13, 1); //rkm el screen 4
    if (therm5val_f_new != therm5val_f_avg_round)
    therm5val_f_new = screen_write(therm5val_f_avg_round, 11, 2, 15, 1); // rkm el screen 5
    if (therm6val_f_new != therm6val_f_avg_round)
    therm6val_f_new = screen_write(therm6val_f_avg_round, 11, 3, 15, 1); //rkm el screen 6
  Serial.print(trans2pressure_avg_int,0);
  Serial.print(",");
  Serial.print(trans1pressure_avg_int,0);
  Serial.print(",");
  Serial.print(therm1val_f_avg_round,1);
  Serial.print(",");
  Serial.print(therm2val_f_avg_round,1);
  Serial.print(",");
  Serial.print(therm3val_f_avg_round,1);
  Serial.print(",");
  Serial.print(therm4val_f_avg_round,1);
  Serial.print(",");
  Serial.print(therm5val_f_avg_round,1);
  Serial.print(",");
  Serial.print(therm6val_f_avg_round,1);
  Serial.print("\n");
  delay(2000);
  lcd.clear();
//Functions Below
//function for weighted average used for thermistors & transducers
float averagefunction(float &avgtemp, float thermval, float coeff1, float coeff2){
  return avgtemp= coeff1*avgtemp + coeff2*thermval;
//function for thermistor positive celsius to fahrenheit
float thermistor_to_temp_f(float thermistor_val){
  float temp_f= ((thermistor_val)/10.0)*1.8 + 32.0;
  return temp_f;
//function for rounding to n decimal places
float rounding_function(float value, int n ){
  int integer = round(value * pow(10.0, n)); //make into integer to later round to n decimal places
  float value_round = integer / pow(10.0, n);
  return value_round;
//function for voltage from adc value
float voltage(float value){
   float voltage_value= (5.0 * value / 1023.0);
   return voltage_value;
//function to write over and clear characters
float screen_write(float avg_round, int x, int y, int z, int n){
    if (avg_round >=100) // rewrites over values greater than or equal to 100
     lcd.setCursor (x, y); //off set location for print value
     lcd.print(avg_round, n); //display n dec place
     float value = avg_round;
      return value;
    else //if value less than 100, write blank space over previous last digit to remove artifact
      lcd.setCursor(z, y); //set new cursor location for blank character
      lcd.print(" ");
      return value;
Thank you!
Also, I am using Arduino Mega2560!!!
define what you mean by iteration of "my code running" , do you mean the 20 loops of the entire main loop
or two loops of the for loop thats counting to 10.
What values are being printed to serial monitor when LCD goes blank?
can you serial print what the screen write function is returning?
what library are you using for LCD link?
When the loop hits 20 , What number are you trying to write to screen that that point?
I have an issue with my LCD I have been trying to work it out that it should display for quite long but it ain't doing and am using Arduino Uno R3 SMD it will only show the boxes but no didgit or letter pls help if u can!
@chieflegend you might be better starting a new separate thread for that.
Ok thanks buddy
This topic was automatically closed after 120 days. New replies are no longer allowed.
