Hi All,
I can not figure out why my const int's from line 24 and 25 disappear after they are put in variable emptyDistance. After reading that a button is pressed I put "emptyValue1"(the empty distance of that tank) into "emptyDistance" (for display later). The Serial.print displays the correct value on line 92 but later when I need that value in line 133 it returns a value of 0.
I can not see why the correct value disappears.
The Serial print values returned are, emptyValue1:
28
emptyDistance 28
graphing 29
emptyDistance 0
start Y 1
adjustedEmpty 99
end
emptyValue2:
35
emptyDistance 35
graphing 13
emptyDistance 0
start Y 1
adjustedEmpty 44
end
Sketch:
// this sketch uses two HC-SR04 ultrasonic boards to report the levels of two tanks
// Tank to be read is determined by reading two switches
// results are displayed on a OLED display using a bargraph and text
#include <Adafruit_SSD1306.h>
#include <Wire.h>
#define OLED_RESET 4 // reset for OLED display
#define trigPin 2 // Set Sensor triger for tank 1 // set Ultrasonic boards trig and echo
#define echoPin 3 // Set Sensor echo for tank 1
#define trigPin2 4 // Set Sensor triger for tank 2
#define echoPin2 5 // Set Sensor echo for tank 2
const int switchPin1= 10; // set button 1 , config as INPUT PULLUP with switch to ground
const int switchPin2= 11; //sets button 2 same as button 1
const String whatTank("what Tank");
int x=1; // preset for loop counter, not implemented yet
int y =(1); // set graphing to start positionof bar
int emptyDistance = 0; //Set empty value for display bar
const int emptyValue1 = 28; // set emptyValue of tank 1 in inches
const int emptyValue2 = 35; // set emptyValue of tank 2 in inches
int adjustedEmpty;
Adafruit_SSD1306 display(OLED_RESET);
int buttonState1= HIGH; // presets buttons
int buttonState2= HIGH;
float pingTime; // time to object and back
float targetDistance; //calculated distance
Serial.begin (9600); // put your setup code here, to run once
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
pinMode(trigPin, OUTPUT); // setup ports for UltraSensor1
pinMode(echoPin, INPUT);
pinMode(trigPin2, OUTPUT); // setup ports for UltraSensor2
pinMode(echoPin2, INPUT);
pinMode(switchPin1, INPUT_PULLUP); // configure switch inputs with pullup
pinMode(switchPin2, INPUT_PULLUP);
digitalWrite(trigPin, LOW); // make sure trigPin is low
digitalWrite(trigPin2, LOW); // make sure trigPin2 is low
display.clearDisplay(); // clear display
display.display(); // send clear to display
void sendPulse(int triger, int echo){ // loop to get range data
digitalWrite( triger, LOW);
delayMicroseconds(5);
digitalWrite( triger, HIGH);
delayMicroseconds(1);
pingTime = pulseIn( echo, HIGH); // ping time in microSeconds from echoPin
targetDistance= (pingTime *0.0135039 /2.0); // Speed of Sound 0.035039 in/sec
return;
buttonState1= digitalRead(switchPin1);
buttonState2= digitalRead(switchPin2);
while (buttonState1== HIGH && buttonState2 == HIGH){
display.display();
if(buttonState1 == LOW){
int triger = trigPin;
int echo = echoPin;
int emptyDistance = emptyValue1;
Serial.println(emptyValue1);
Serial.print("emptyDistance ");Serial.println(emptyDistance);
whatTank = (" Grey 1");
sendPulse(triger,echo);
if(buttonState2 ==LOW){
int triger = trigPin2;
int echo = echoPin2;
int emptyDistance = emptyValue2;
Serial.println(emptyValue2);
whatTank =(" Grey 2");
sendPulse(triger, echo);
for ( int createBar = 17; createBar < 100; createBar ++){ // create bar that returned distance removes
for ( int y = 17; y <27; y++) {
display.drawPixel(createBar , y , WHITE); // draw lines to create Bar from 17 to 26
display.setTextSize(2); // Set Text size for display on OLED
display.setTextColor(WHITE); // Set Text color
display.setCursor(0,0); // Set text position
display.print(whatTank);
display.setCursor(0,15);
display.print("F");
display.setCursor(100,15);
display.print(" E");
display.setCursor(5,30);
display.print(targetDistance); display.print(" in");
display.setCursor(20,50);
display.print("From Top");
display.display();
int graphing = targetDistance; // convert targetDistance to a hole number
Serial.print("graphing ");Serial.println(graphing);
Serial.print("emptyDistance "); Serial.println(emptyDistance);
adjustedEmpty = map(graphing , 0 , 29 , 0 , 99); // adjustedEmpty maped to emptyDistance set here to 29
Serial.print("start Y "); Serial.println(y);
Serial.print("adjustedEmpty "); Serial.println(adjustedEmpty);
for(x =18; x < adjustedEmpty ; x++ ){ // writes black over drawn bar to simulate level
for ( int y = 18; y <26; y++) { // set hight of BLACK bar to erace lines from 10 to 25
display.drawPixel(x , y , BLACK);
display.display();
delay (3000);
Serial.println("end");
display.display();
