Disassembler Tool
Hello all,
I have found this Disassembler Tool and i think is worth sharing
http://www.forward.com.au/pfod/ArduinoProgramming/index.html
installation works (after virus scan)
then I get an error message
Exception in thread "Thread-9" java.lang.NoSuchMethodError: processing.app.SerialMonitor.closeSerialPort()V
at au.com.forward.arduinoTools.Disassembler.internalRun(Disassembler.java:109)
at au.com.forward.arduinoTools.Disassembler$1.run(Disassembler.java:83)
Strange...for me it works, i am using 1.0.5 r2, maybe is a version issue?
Here is my code test
svolatile byte I0, I1;
volatile unsigned int T1OFC;//Timer1 Overflow Count
unsigned long a = 0;
            a=myFastTime();
unsigned long myFastTime()
            unsigned long tmp = 0;// temporary variable to hold the value
            cli();//disable interrupts
            tmp = ((T1OFC * 65536UL) + (uint32_t)TCNT1 - 10UL);//get the value -10 to compensate the call of myFastTime()
            sei();
            return tmp;
the result is
  a8:	f8 94       	cli
  aa:	20 91 00 01 	lds	r18, 0x0100
  ae:	30 91 01 01 	lds	r19, 0x0101
  b2:	80 91 84 00 	lds	r24, 0x0084
  b6:	90 91 85 00 	lds	r25, 0x0085
            sei();
  ba:	78 94       	sei
            a=myFastTime();
  bc:	a0 e0       	ldi	r26, 0x00	; 0
  be:	b0 e0       	ldi	r27, 0x00	; 0
  c0:	0a 97       	sbiw	r24, 0x0a	; 10
  c2:	a1 09       	sbc	r26, r1
  c4:	b1 09       	sbc	r27, r1
  c6:	40 e0       	ldi	r20, 0x00	; 0
  c8:	50 e0       	ldi	r21, 0x00	; 0
  ca:	a9 01       	movw	r20, r18
  cc:	33 27       	eor	r19, r19
  ce:	22 27       	eor	r18, r18
  d0:	82 0f       	add	r24, r18
  d2:	93 1f       	adc	r25, r19
  d4:	a4 1f       	adc	r26, r20
  d6:	b5 1f       	adc	r27, r21
  d8:	80 93 02 01 	sts	0x0102, r24
  dc:	90 93 03 01 	sts	0x0103, r25
  e0:	a0 93 04 01 	sts	0x0104, r26
  e4:	b0 93 05 01 	sts	0x0105, r27
  e8:	08 95       	ret
I am not good at assembly, so i need someone to check the result
It takes 10 clock cycles for myFastTime() and 28 to complete one loop (a=myFastTime()) including return?
instruction - cycles needed - http://www.atmel.com/images/Atmel-0856-AVR-Instruction-Set-Manual.pdf
cli - 1
lds - 2
sei - 1
ldi - 1
sbiw - 2
sbc - 1
movw - 1
eor - 1
add - 1
adc - 1
sts - 2
ret - 5
