Hallo everybody,
i need help with this code.
The code is working but i need seconds too. hh:mm:ss
How can i resolve this.
Thanks for help
// Use the DS1307 clock module
#define USE_DS1307 1
// Header file includes
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#include "Font_Data.h"
#if USE_GENERIC_HW || USE_PAROLA_HW
#define INVERT_UPPER_ZONE
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define MAX_ZONES 2
#define ZONE_SIZE 8
#define MAX_DEVICES (MAX_ZONES * ZONE_SIZE)
//#define MAX_DEVICES 16
#define ZONE_UPPER 1
#define ZONE_LOWER 0
#define CLK_PIN 14
#define DATA_PIN 13
#define CS_PIN 15
#if USE_DS1307
#include <MD_DS1307.h>
#include <Wire.h>
#endif
// Hardware SPI connection
//MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
// Arbitrary output pins
MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
#define SPEED_TIME 75
#define PAUSE_TIME 0
#define MAX_MESG 10
// Turn on debug statements to the serial output
#define DEBUG 0
// Global variables
char szTimeL[MAX_MESG]; // mm:ss\0
char szTimeH[MAX_MESG];
void getTime(char *psz, bool f = true)
// Code for reading clock time
// Simulated clock runs 1 minute every second
#if USE_DS1307
RTC.readTime();
sprintf(psz, "%02d%c%02d", RTC.h, (f ? ':' : ' '), RTC.m);
#else
uint16_t h, m, s;
m = millis()/1000;
h = (m/60) % 24;
m %= 60;
sprintf(psz, "%02d%c%02d", h, (f ? ':' : ' '), m);
#endif
void createHString(char *pH, char *pL)
for (; *pL != '\0'; pL++)
*pH++ = *pL | 0x80; // offset character
*pH = '\0'; // terminate the string
void setup(void)
// initialise the LED display
P.begin(MAX_ZONES);
// Set up zones for 2 halves of the display
P.setZone(ZONE_LOWER, 0, ZONE_SIZE - 1);
P.setZone(ZONE_UPPER, ZONE_SIZE, MAX_DEVICES - 1);
P.setFont(numeric7SegDouble);
P.setCharSpacing(P.getCharSpacing() * 2); // double height --> double spacing
#ifdef INVERT_UPPER_ZONE
P.setZoneEffect(ZONE_UPPER, true, PA_FLIP_UD);
P.setZoneEffect(ZONE_UPPER, true, PA_FLIP_LR);
P.displayZoneText(ZONE_LOWER, szTimeL, PA_RIGHT, SPEED_TIME, PAUSE_TIME, PA_PRINT, PA_NO_EFFECT);
P.displayZoneText(ZONE_UPPER, szTimeH, PA_LEFT, SPEED_TIME, PAUSE_TIME, PA_PRINT, PA_NO_EFFECT);
#else
P.displayZoneText(ZONE_LOWER, szTimeL, PA_CENTER, SPEED_TIME, PAUSE_TIME, PA_PRINT, PA_NO_EFFECT);
P.displayZoneText(ZONE_UPPER, szTimeH, PA_CENTER, SPEED_TIME, PAUSE_TIME, PA_PRINT, PA_NO_EFFECT);
#endif
#if USE_DS1307
RTC.control(DS1307_CLOCK_HALT, DS1307_OFF);
RTC.control(DS1307_12H, DS1307_OFF);
#endif
void loop(void)
static uint32_t lastTime = 0; // millis() memory
static bool flasher = false; // seconds passing flasher
P.displayAnimate();
P.setIntensity(1); // Display Intensity
if (P.getZoneStatus(ZONE_LOWER) && P.getZoneStatus(ZONE_UPPER))
// Adjust the time string if we have to. It will be adjusted
// every second at least for the flashing colon separator.
if (millis() - lastTime >= 1000)
lastTime = millis();
getTime(szTimeL, flasher);
createHString(szTimeH, szTimeL);
flasher = !flasher;
P.displayReset();
// synchronise the start
P.synchZoneStart();
