Discover Arduino
Hi everyboy :slight_smile:
I'm discovering Arduino and its programmation and i'm coding a simple code to test Arduino Uno. But i don't understand why it doen't work. I already code in C and it's pretty similar. Here's my code:
#define P_PV A0
#define P_R A1
#define P_C A2
#define K_PV 2
#define K_R 3
int PV, C;
pinMode(P_PV, INPUT);
pinMode(P_R, INPUT);
pinMode(P_C, INPUT);
pinMode(K_PV, OUTPUT);
pinMode(K_R, OUTPUT);
digitalWrite(K_R, LOW);
digitalWrite(K_PV, LOW);
PV=analogRead(P_PV);
C=analogRead(P_C);
if(PV>C)
digitalWrite(K_R, HIGH);
No need to explain it, i'm just using a if(). But i don't know why, i can compil and transfer the code to Arduino but digital outputs aren't work in function of the analogic inputs. Can you help me?
Thanks :slight_smile:
How do you know the outputs aren’t correct?
I’d suggest you use Serial to debug, perhaps printing the values as it reads them, and then printing a message to say which part of the if it is in. See my <<<<<<< comments below.
#define P_PV A0
#define P_R A1
#define P_C A2
#define K_PV 2
#define K_R 3
int PV, C;
Serial.begin(9600); //<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Serial.println("Starting...."); //<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Serial.println(PV); //<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    C=analogRead(P_C);
Serial.println(C); //<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    if(PV>C)
Serial.println("In the PV > C part of the if"); //<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Serial.println("In the else part"); //<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Yes, there is. What is attached to the analog pins?
Analog pins are INPUT only, so there is no need to use the pinMode() statement for analog pins.
int PV, C;
Why are these variables, used only in loop(), global?
    if(PV>C)
If PV is greater than C, set the K_PV pin LOW. Otherwise, set the K_PV pin LOW. I see.
Ok JimboZA, I will. I can't do it now because I don't have the materials to make it but it will be efficient to found the bug with this function.
PaulS
I just put 2 voltage generator in the analog inputs. I change the voltage of its between 0 and 5V to test the if(). After I watch the digital outputs on an oscilloscope.
For pinMode() use for the analog inputs, I know they are inputs but I don't know very well Arduino and use pinMode() for analog inputs was a kind of security. Useless but I put it to be sure.
About the PV and C variables, I don't understand where you want to use it? They're just useful in the loop()
One more time, simple security, I can't make a simple code works on Arduino, so when I'll make a good code, I'll erase useless lines one by one and test if I really can do it.
You do not say what form these voltage generators take but do they have a common GND with the Arduino ?
Arf... It must be that... I made a common GND but I forget to put this GND on a GND pin from Arduino...
I guess no need to link the GND from digital I/O to analog inputs GND? They're already linked?
Yes.
Ok JimboZA, I will. I can’t do it now because I don’t have the materials to make it but it will be efficient to found the bug with this function.
You don’t need any materials to do what I suggested: Serial output is to the IDE monitor (contril-shift-M) through the usb cable.
