Dispenser with Servo that rotates on alarm. ERROR.
I’m in an electronic class at my college and basically my professor threw us into arduino programming for our final project without ever teaching it before. I have no background knowledge of C++ programming or arduino programming. I’ve never used an arduino, nor have I ever programmed before.
If anyone can help me get this code correct so I can at least pass this class, I would be forever grateful!!
Attatched is my code currently.
My error codes are as follows:
Arduino: 1.6.12 (Windows 10), Board: “Arduino/Genuino Uno”
project:30: error: stray ‘\342’ in program
{ When “morningAlarm� time reached do this… if (sensorValue < 341)}
project:30: error: stray ‘\200’ in program
project:30: error: stray ‘\234’ in program
project:30: error: stray ‘\235’ in program
project:30: error: stray ‘\246’ in program
project:32: error: stray ‘\342’ in program
If potentiometer value is less than 341 do this… for (int i=1; i<=100; i=i+1 ) Repeat the following code 100 times.
project:32: error: stray ‘\200’ in program
project:32: error: stray ‘\246’ in program
project:34: error: stray ‘\342’ in program
Serial.println(“Activate Servo�);
project:34: error: stray ‘\200’ in program
project:34: error: stray ‘\234’ in program
project:34: error: stray ‘\235’ in program
project:35: error: stray ‘\342’ in program
Print “Activate Servo� on serial monitor. myservo.write(110,240,true);
project:35: error: stray ‘\200’ in program
project:35: error: stray ‘\234’ in program
project:35: error: stray ‘\235’ in program
project:40: error: stray ‘\342’ in program
{ if (sensorValue > 341 && sensorValue < 682) If potentiometer value is between 341 and 682 do this… { for (int i=1; i<=80; i=i+1 ) Repeat the following code 80 times.
project:40: error: stray ‘\200’ in program
project:40: error: stray ‘\246’ in program
project:41: error: stray ‘\342’ in program
project:41: error: stray ‘\200’ in program
project:41: error: stray ‘\234’ in program
project:41: error: stray ‘\235’ in program
project:42: error: stray ‘\342’ in program
project:42: error: stray ‘\200’ in program
project:42: error: stray ‘\234’ in program
project:42: error: stray ‘\235’ in program
project:46: error: stray ‘\342’ in program
{ if (sensorValue > 682 && sensorValue < 1200) If potentiometer value is between 682 and 1200 do this… { for (int i=1; i<=60; i=i+1 ) Repeat the following code 60 times.
project:46: error: stray ‘\200’ in program
project:46: error: stray ‘\246’ in program
project:47: error: stray ‘\342’ in program
project:47: error: stray ‘\200’ in program
project:47: error: stray ‘\234’ in program
project:47: error: stray ‘\235’ in program
In file included from C:\Users\P\Documents\Arduino\project\project.ino:12:0:
C:\Users\P\Documents\Arduino\libraries\VarSpeedServo-master/VarSpeedServo.h: In function ‘void loop()’:
C:\Users\P\Documents\Arduino\libraries\VarSpeedServo-master/VarSpeedServo.h:112:16: error: redeclaration of ‘_timer1’
typedef enum { _timer1, _Nbr_16timers } timer16_Sequence_t ;
In file included from C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:63:0,
from C:\Users\P\Documents\Arduino\project\project.ino:11:
C:\Program Files (x86)\Arduino\libraries\Servo\src/avr/ServoTimers.h:57:16: note: previous declaration ‘loop()::timer16_Sequence_t _timer1’
typedef enum { _timer1, _Nbr_16timers } timer16_Sequence_t;
C:\Users\P\Documents\Arduino\libraries\VarSpeedServo-master/VarSpeedServo.h:112:25: error: redeclaration of ‘_Nbr_16timers’
C:\Program Files (x86)\Arduino\libraries\Servo\src/avr/ServoTimers.h:57:25: note: previous declaration ‘loop()::timer16_Sequence_t _Nbr_16timers’
C:\Users\P\Documents\Arduino\libraries\VarSpeedServo-master/VarSpeedServo.h:112:41: error: conflicting declaration ‘typedef enum loop()::timer16_Sequence_t timer16_Sequence_t’
C:\Program Files (x86)\Arduino\libraries\Servo\src/avr/ServoTimers.h:57:41: note: previous declaration as ‘typedef enum loop()::timer16_Sequence_t timer16_Sequence_t’
C:\Users\P\Documents\Arduino\libraries\VarSpeedServo-master/VarSpeedServo.h:133:3: error: conflicting declaration ‘typedef struct loop()::ServoPin_t ServoPin_t’
} ServoPin_t ;
In file included from C:\Users\P\Documents\Arduino\project\project.ino:11:0:
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:87:3: note: previous declaration as ‘typedef struct loop()::ServoPin_t ServoPin_t’
} ServoPin_t ;
C:\Users\P\Documents\Arduino\libraries\VarSpeedServo-master/VarSpeedServo.h:140:3: error: conflicting declaration ‘typedef struct loop()::servo_t servo_t’
} servo_t;
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:92:3: note: previous declaration as ‘typedef struct loop()::servo_t servo_t’
} servo_t;
In file included from C:\Users\P\Documents\Arduino\libraries\TimeAlarms/TimeAlarms.h:7:0,
from C:\Users\P\Documents\Arduino\project\project.ino:13:
C:\Users\P\Documents\Arduino\libraries\arduino_802316/TimeLib.h:33:8: error: expected unqualified-id before string constant
extern “C++” {
project:50: error: expected ‘}’ at end of input
myservo.write(0,240,true); Move servo arm back to 0degrees, with a speed of 240 and wait until complete delay(500);}}}
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
project.ino (2.05 KB)
You should use the code button </> and properly indent your code so it looks like this and is easy to read
    #include <Servo.h>
    #include <VarSpeedServo.h>
    #include <TimeAlarms.h>
    #include <Time.h>
    #include <TimeLib.h>
    Servo myservo
    const int servopin = 9
    int potpin = 0
    int val
        Serial.begin(9600); Sets the data rate setTime(8,29,50,1,1,11);
        Manually set the time Alarm.alarmRepeat(8,30,0, MorningAlarm);
        myservo.attach(servoPin);
        object myservo.write(0,255,true);
            int sensorValue = analogRead(A0);
            Serial.println(sensorValue);
            void MorningAlarm() {
                When “morningAlarm” time reached do this… if (sensorValue < 341)
            Serial.println(“Activate Servo”);
            Print “Activate Servo” on serial monitor. myservo.write(110,240,true);
            Move servo arm to 110degrees, with a speed of 240 and wait until complete delay(500);
            Move servo arm to 110degrees, with a speed of 240 and wait until complete delay(500); myservo.write(0,240,true);
            Print "Activate Servo" on serial monitor. myservo.write(110,240,true);
I don’t believe I have ever seen a mess like this. There is so much wrong that I don’t know where to start.
You seem to have comments that are not preceeded by //
You are trying to define functions inside other functions. That is not allowed
You have duplicate function names. That is not allowed.
You have code that is not inside any function. That is not allowed.
…R
Here is your program in a form that will compile.
VarSpeedServo myservo;
const int servoPin = 9;
const int potPin = A0;
  Serial.begin(9600); // Sets the data rate
  setTime(8, 29, 50, 1, 1, 11);  // Manually set the time
  Alarm.alarmRepeat(8, 30, 0, MorningAlarm);
  myservo.attach(servoPin);  // object myservo.write(0, 255, true);
  Serial.println(analogRead(potPin));
  delay(1000);  // Don't want to flood the output
// When “morningAlarm” time reached do this…
  int sensorValue = analogRead(potPin);
  if (sensorValue < 341) {
    // If potentiometer value is less than 341 do this…
    for (int i = 1; i <= 100; i = i + 1 ) {
      // Repeat the following code 100 times.
      Serial.println("Activate Servo");
      myservo.write(110, 240, true); // Move servo arm to 110degrees, with a speed of 240
      delay(500); // Wait until complete
      myservo.write(0, 240, true); // Move servo arm back to 0degrees, with a speed of 240
  if (sensorValue > 341 && sensorValue < 682) { // If potentiometer value is between 341 and 682 do this…
    for (int i = 1; i <= 80; i = i + 1 ) {
      // Repeat the following code 80 times.
      myservo.write(0, 240, true);  // Move servo arm back to 0 degrees, with a speed of 240
  if (sensorValue > 682 && sensorValue < 1200) {  // Analog input only goes to 1023
    //If potentiometer value is between 682 and 1200 do this…
    for (int i = 1; i <= 60; i = i + 1 ) {
      //Repeat the following code 60 times.
My God.
Dude, do a C++ tutorial. There are heaps of them on the web - pick one. It scarcely needs to be said that
1 - if learning a bit of C++ is a requirement for your course; and
2 - you don't do it; and
3 - you get other people to write your assignments for you,
Then not only do you not deserve to pass your course, you have committed academic fraud. If you feel that you oughtn't have to learn programming to pass an electronics course, I defy you to find an electronic device manufactured these days without a microcontroller. Hell: drills and power saws these days have microcontrollers in them to control the speed and manage heat.
Do a C++ tutorial. There are heaps of them on the web - pick one. Don't complain that your prof hasn't taught you this stuff. Once you get out of high school, your prof isn't there to teach you: they are just there to tell you what to need to study.
