cevepe
August 25, 2021, 7:01pm
1
How to make a function for LCD 1602 so that I don't have to write 5 lines all the time, but use only one line and that's it.
For example: printLCD (TEXT_1, TEXT_2) ;
Thank you very much for your help
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(TEXT_1);
lcd.setCursor(0, 1);
lcd.print(TEXT_2);
void printLCD(TEXT_1, TEXT_2) {
lcd.clear();
lcd.print(TEXT_1);
lcd.print(TEXT_2);
void printLCD(char* TEXT_1, char* TEXT_2)
lcd.clear();
lcd.print(TEXT_1);
lcd.print(TEXT_2);
Hi @anon57585045 @anon73444976
A question for me to learn.
In this function, what is the advantage when using
or
void printLCD(char TEXT_1, char TEXT_2) (without the *)
RV mineirin
The first one passes a C string, the second passes only one character.
I guess you could do both, and allow the compiler to do the overloads
I assumed (perhaps wrongly) that TEXT meant more than a single character.
@cevepe
you could use a template to spare a lot of overloads
template < typename T0, typename T1>
void printLCD(T0 line0, T1 line1)
lcd.clear();
//lcd.setCursor(0, 0); // done by clear anyway
lcd.print(line0);
lcd.print(line1);
this enables you do print out more than just char*,
Examples:
printLCD("test", "string lit");
printLCD("char", 'x');
String aString = "FooFoo";
printLCD("String", aString);
printLCD("int", 1234);
printLCD(1234, "int");
printLCD("float", 12.34);
printLCD(12.34, "float");
printLCD(12.34, F("mixed with F-Makro"));
but if you need really a function for "that i don't have to write 5 lines all the time" ... and if you really need it a lot in your sketch, you might consider other concepts, for example holding the data in PROGMEM or using the F-Makro
system
Closed
December 24, 2021, 5:14am
11
