Hello,
I'm facing an issue with TFT displays from buydisplay. I need to display a BMP file from an SD card.
The display with the RA8875 controller works fine with a Due, using the example code from the library.
https://www.buydisplay.com/serial-spi-arduino-8-inch-tft-lcd-touch-shield-ra8875-for-mega-due-uno
But the one with the SSD1963 doesn't work with the library examples. I tried several libraries and sketches found on the web (included UTFT_SdRaw), but never managed to get a picture on the screen. The SD card gets a connection confirmation, I get the Serial message showing that the picture has been loaded, but the screen remains white.
https://www.buydisplay.com/8-inch-arduino-touch-screen-shield-ssd1963-library-for-mega-due
Screen jumpers J1-J2-J3 are open, J4-J5-J6 are closed. Shield hardware SPI jumpers are closed.
I want to switch from the RA8875 to the SSD1963 as I read that the pictures from SD card can be displayed much faster with the SSD1963. If someone can advice me another way to go faster with the RA8875, that could also solve my issue.
Changing from MEGA to DUE to GIGA doesn't help. All work fine with the RA8875, none with the SSD1963.
Here are the 2 examples codes from the Buydisplay libraries : the 1st one works fine with RA8875, while the 2nd one doesn't work with SSD1963:
// Web: http://www.buydisplay.com
EastRising Technology Co.,LTD
Examples for 800x480 TFT LCD Module with RA8875 Controller
Hardware SPI,4-Wire SPI Interface,5V Power Supply
Micro SD Card (TF Card) Demonstration
Don't foget to copy images from bmp folder to your TF card and insert to SD card slot of shield.
#include <Adafruit_GFX.h> // Core graphics library
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
#include "Adafruit_RA8875.h"
#define sd_cs 5 // uding ethernet shield sd
// Library only supports hardware SPI at this time
//Arduino DUE,Arduino mega2560,Arduino UNO
#define RA8875_INT 4
#define RA8875_CS 10
#define RA8875_RESET 9
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
void setup () {
if (!SD.begin(sd_cs))
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
Serial.println("RA8875 start");
/* Initialise the display using 'RA8875_480x272' or 'RA8875_800x480' */
if (!tft.begin(RA8875_800x480)) {
Serial.println("RA8875 Not Found!");
while (1);
Serial.println("Found RA8875");
tft.displayOn(true);
tft.GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft.PWM1out(255);
Serial.print("(");
Serial.print(tft.width());
Serial.print(", ");
Serial.print(tft.height());
Serial.println(")");
tft.graphicsMode(); // go back to graphics mode
tft.fillScreen(RA8875_BLACK);
tft.graphicsMode();
bmpDraw("BMP_1.bmp", 0, 0);
bmpDraw("BMP_2.bmp", 0, 0);
bmpDraw("BMP_3.bmp", 0, 0);
bmpDraw("BMP_4.bmp", 0, 0);
bmpDraw("BMP_5.bmp", 0, 0);
bmpDraw("BMP_6.bmp", 0, 0);
bmpDraw("BMP_7.bmp", 0, 0);
bmpDraw("BMP_8.bmp", 0, 0);
bmpDraw("BMP_9.bmp", 0, 0);
bmpDraw("BMP_10.bmp", 0, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates. It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel). Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster. 20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, int x, int y) {
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
uint16_t lcdbuffer[BUFFPIXEL]; // pixel out buffer (16-bit per pixel)
uint8_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
uint8_t r, g, b;
uint32_t pos = 0, startTime = millis();
uint8_t lcdidx = 0;
boolean first = true;
if((x >= tft.width()) || (y >= tft.height())) return;
Serial.print(F("Loading image '"));
Serial.print(filename);
Serial.println('\'');
// Open requested file on SD card
if ((bmpFile = SD.open(filename)) == NULL) {
Serial.println(F("File not found"));
return;
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
Serial.println(F("File size: "));
Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
Serial.print(F("Image Offset: "));
Serial.println(bmpImageoffset, DEC);
// Read DIB header
Serial.print(F("Header size: "));
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
Serial.print(F("Bit Depth: "));
Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
Serial.print(F("Image size: "));
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * 3 + 3) & ~3;
// If bmpHeight is negative, image is in top-down order.
// This is not canon but has been observed in the wild.
if(bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
// Crop area to be loaded
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= tft.width()) w = tft.width() - x;
if((y+h-1) >= tft.height()) h = tft.height() - y;
// Set TFT address window to clipped image bounds
for (row=0; row<h; row++) { // For each scanline...
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col=0; col<w; col++) { // For each column...
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
// Push LCD buffer to the display first
if(lcdidx > 0) {
tft.drawPixel(col, row, lcdbuffer[lcdidx]);
lcdidx = 0;
first = false;
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// Convert pixel from BMP to TFT format
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
lcdbuffer[lcdidx] = color565(r,g,b);
} // end pixel
} // end scanline
// Write any remaining data to LCD
if(lcdidx > 0) {
Serial.print(F("Loaded in "));
Serial.print(millis() - startTime);
Serial.println(" ms");
} // end goodBmp
bmpFile.close();
if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
uint16_t color565(uint8_t r, uint8_t g, uint8_t b) {
return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
//Web: http://www.buydisplay.com
Examples for ER-TFTM070-4V2.1(800x480 Pixels)
ER-TFTM070-4V2.1 with no touch panel sets power supply to 5V and 8080-16BIT parallel interface.Meanwhile the Hardware SPI on shield should be short and Software SPI should be open.Capacitive Touch Screen on shield should be short and Resistive Touch Panel should be open.
ER-TFTM070-4V2.1 with Resistive touch panel sets power supply to 5V and 8080-16BIT Parallel interface. Meanwhile the Hardware SPI on shield should be open and Software SPI should be short.Capacitive Touch Screen on shield should be open and Resistive Touch Panel should be open either.
Don't foget to copy images from bmp folder to your TF card and insert to SD card slot of arduino shield.
Tested and worked with:
Arduino Mega 2560,Arduino Due
Works with Arduino 1.6.0 IDE
#include <Wire.h>
#include <UTFT.h>
#include <SPI.h>
#include <SD.h>
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins.
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(SSD1963_800480,38,39,40,41); //(byte model, int RS, int WR, int CS, int RST, int SER)
#define SD_CS 47
int dispx, dispy;
void setup(void) {
// Setup the LCD
myGLCD.InitLCD();
pinMode(8, OUTPUT); //backlight
digitalWrite(8, HIGH);//on
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 799, 479);
dispx=myGLCD.getDisplayXSize();
dispy=myGLCD.getDisplayYSize();
Serial.print("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("failed!");
Serial.println("OK!");
// good balance.
File bmpFile;
int w, h, row, col;
uint8_t r, g, b;
uint8_t lcdidx = 0;
if((x >= dispx) || (y >= dispy)) return;
return;
// Parse BMP header
// Read DIB header
Serial.print('x');
if(bmpHeight < 0) {
flip = false;
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= dispx) w = dispx - x;
if((y+h-1) >= dispy) h = dispy - y;
bmpFile.seek(pos);
if(lcdidx > 0) {
myGLCD.setColor(lcdbuffer[lcdidx]);
myGLCD.drawPixel(col, row);
lcdidx = 0;
first = false;
myGLCD.setColor(r,g,b);
} // end pixel
} // end scanline
if(lcdidx > 0) {
} // end goodBmp
bmpFile.close();
uint16_t result;
return result;
uint32_t result;
return result;
