Display a value on the Nokia 5110 LCD Module
I'm able to display text on the Nokia 5110 Module, but not values.
For instance
LcdString("123") displays 123
But
int a=123;
LcdString(a);
returns the following error when compiling:
v3_with_LCD:308: error: invalid conversion from 'int' to 'char*'
v3_with_LCD:308: error: initializing argument 1 of 'void LcdString(char*)'
This is LCD String:
void LcdString(char *characters)
  while (*characters)
    LcdCharacter(*characters++);
and this is LcdCharater:
void LcdCharacter(char character)
  LcdWrite(LCD_D, 0x00);//Blank vertical line padding
  for (int index = 0; index < 5; index++)
    LcdWrite(LCD_D, ASCII[character - 0x20][index]);//0x20 is the ASCII character for Space (' '). The font table starts with this character
So I tried to convert the integer into a string - with no success:
int a=123;
  String astring=String(a);
  LcdString(astring);
Error message:
v3_with_LCD.cpp: In function 'void setup()':
v3_with_LCD:310: error: cannot convert 'String' to 'char*' for argument '1' to 'void LcdString(char*)'
Any help most welcome!
The compiler is telling exactly what the problem is - a String object is not the same as a char*.
There is a String method to convert into a char buffer.
There is also a function, itoa(), to convert the integer directly to a char array without wasting the resources required by the String class.
You can try the following - I did it as could not print integers as well...
int humid;
int temp;
String humid_r = "0";
String temp_r = "0";
humid_r = humid;
temp_r = temp;
Just save the int as string and print it as string. This works
