Display achtergrond kleur, hoe pas je dit aan?
Display achtergrond kleur, hoe pas je dit aan? an zwart naar wit? en witte letters, maar dat kan je wel aanpassen in de sketch, maar de achtergrond kleur is niet aangegeven.
hier de gebruikte sketch:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define MSG1_PIN   2
#define MSG2_PIN   3
#define MSG3_PIN   4
#define MSG4_PIN   5
#define MSG5_PIN   6
#define MSG6_PIN   7
#define MSG7_PIN   8
#define MSG8_PIN   9
#define TMIN       5 // departure time of next train, minimum of random time
#define TMAX      13 // departure time of next train, maximum of random time
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
byte hour, minute;
byte msgnr,msgnr_old, msgflag, msghour, msgminute;
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
void calc_msg_time() {
  msgminute = minute + random(TMIN, TMAX);
  msghour = hour;
  if (msgminute > 59) {
    msghour = (msghour + 1) % 24;
    msgminute = msgminute - 60;
  randomSeed (analogRead(0));
  hour   = random(7, 20);
  minute = random(0, 60);
  pinMode (MSG1_PIN, INPUT_PULLUP);
  pinMode(MSG2_PIN,  INPUT_PULLUP);
  pinMode (MSG3_PIN, INPUT_PULLUP);
  pinMode (MSG4_PIN, INPUT_PULLUP);
  pinMode (MSG5_PIN, INPUT_PULLUP);
  pinMode (MSG6_PIN, INPUT_PULLUP);
  pinMode (MSG7_PIN, INPUT_PULLUP);
  pinMode (MSG8_PIN, INPUT_PULLUP);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
  delay(2000);
  display.clearDisplay();
  // display time and messages
  if(!digitalRead(MSG1_PIN)) msgnr = 1;
  if(!digitalRead(MSG2_PIN)) msgnr = 2;
  if(!digitalRead(MSG3_PIN)) msgnr = 3;
  if(!digitalRead(MSG4_PIN)) msgnr = 4;
  if(!digitalRead(MSG5_PIN)) msgnr = 5;
  if(!digitalRead(MSG6_PIN)) msgnr = 6;
  if(!digitalRead(MSG7_PIN)) msgnr = 7;
 if(!digitalRead(MSG8_PIN)) msgnr = 8;
  if(msgnr != msgnr_old) {
    calc_msg_time();
    msgnr_old = msgnr;
   display.setTextSize(1);
   display.setTextColor(WHITE);
    switch (msgnr) {
    case 1://vitrains
       display.setCursor(5,0);  display.println("BRUGGE");
      display.setCursor(50,10); display.println("OOSTENDE");
      display.setCursor(115,20); display.println("IC");
       display.setCursor(0, 20);
  if(msghour < 10) display.print(" ");
  display.print(msghour);
  display.print(":");
  if(msgminute < 10) display.print("0");
  display.print(msgminute);
      display.display();
case 2://desiro
      display.setCursor(50,0);  display.println("MECHELEN");
      display.setCursor(5,10); display.println("ANTWERPEN-CENTRAAL");
      display.setCursor(115,20); display.println("S");
  display.print(":");
  display.display();
case 3://benelux
      display.setCursor(5,0);  display.println("ANTWERPEN-CENTRAAL");
      display.setCursor(50,10); display.println("AMSTERDAM CS");
  display.print(":");
  display.display();
    case 4://m6
      display.setCursor(50,10); display.println("BLANKENBERGE");
  display.print(":");
  display.display();
    case 5://am54
      display.setCursor(50,0);  display.println("LEUVEN");
      display.setCursor(5,10); display.println("LIEGE-GUILLEMINS");
  display.print(":");
  display.display();
case 6://lsmodels
      display.setCursor(5,0);  display.println("Brussel");
      display.setCursor(50,10); display.println("Welkenraedt");
  display.print(":");
  display.display();
    case 7://classic
  display.print(":");
      display.setCursor(42, 0); display.println("IC Direct");
      display.setCursor(0,12);  display.println("Maastricht");
      display.setCursor(0,22); display.println("Via Den Haag");
      display.setCursor(3,0);
  display.display();
    case 8://lsmodels
      display.setCursor(5,0);  display.println("Ettelbruck");
      display.setCursor(50,10); display.println("Luxembourg");
      display.setCursor(115,20); display.println("IR");
  display.print(":");
  display.display();
Zo te zien gebruik je een monochrome OLED display.
Die heeft geen achtergrond.
Elk beeldpuntje is een apart lampje, die kan aan of uit zijn.
in een andere sketch werd er aangegeven wat de bg kleur moet zijn, wit of zwart, maar bij deze sketch word alleen aangegeven wat de tekst kleur moet zijn en niet de bg kleur
Dan kun je in die andere sketch toch afkijken hoe dat gedaan word ?
klopt dat heb ik zeker gedaan, en toevoegd aan de huidige sketsh maar dat pakt ie niet, de achtergrond kleur veranderd niet in wit met zwarte letters
In je eerste post staat een sketch waaruit blijkt dat je gebruik maakt van een Adafruit library.
Daarom verwijs ik naar de Adafruit handleiding (klik !)
Ik raad je aan om dat een paar keer door te lezen, ook al zou je nu denken dat je niet alles daaruit nodig hebt.
Want het is gewoon een behoorlijk uitgebreid en complete handleiding.
Een stukje wat daarin te vinden is, is dit:
  display.invertDisplay(true);
  display.invertDisplay(false);
Hier wordt dus met het display geknipperd tussen wit op zwart, en zwart op wit.
Volgens mij bereik je daarmee waar je om vraagt.
Wat hier in de achtergrond gebeurt, is dat het commando 0xa7 voor inverse display, of 0xa6 voor normaal display wordt verstuurd.
Voor de mens is true of false gemakkelijker te handlen als een hexadecimale code te onthouden.
Daarom zijn dit soort commando's in de library opgenomen als een tabel waarmee alle mogelijke commando's worden afgevangen.
Dus dat zou je eens in je sketch kunnen proberen, nadat je de handleiding een paar keer hebt doorgenomen.
