Hi guys,
First post here so I apologise for any formatting problems, I've read the "READ FIRST" posts so hopefully it's okay.
I'm having an issue with my current Arduino project. I'm using an ATMEGA328p board and I have an 0.96" OLED and BMP180 connected using I2C to pins A4 and A5. I have code that takes the temperature read by the sensor and displays it on the OLED.
#include <SFE_BMP180.h>
#include <Wire.h> //needed for I2C
#include <Adafruit_GFX.h> //needed for OLED screen
#include <Adafruit_SSD1306.h> //needed for OLED screen
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
SFE_BMP180 pressure;
#define ALTITUDE 71
if (pressure.begin())
Serial.println("BMP180 init success");
else{
Serial.println("BMP180 init fail\n\n");
while(1);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C))
Serial.println("failed to access OLED...");
for(;;);
display.clearDisplay(); //clear display buffer
display.setTextSize(1); //set text size
display.setTextColor(WHITE); //set colour of font
display.setCursor(0, 10); //set cursor 0 pixels from left 10 pixels down from top
// Display static text
display.println("Hello, EENG3110!"); //print text to display
display.display(); //this needs to be called to actually update the OLED
char status;
double T,P,p0,a;
status = pressure.startTemperature();
if (status != 0)
delay(status);
status = pressure.getTemperature(T);
if (status != 0)
Serial.print("Temperature: ");
Serial.print(T,2);
Serial.println(" °C");
else Serial.println("error retrieving temperature measurement\n");
else Serial.println("error starting temperature measurement\n");
display.setCursor(0,10);
display.println("Temperature: ");
display.setTextSize(2);
display.setCursor(0,50);
display.println(T, 2);
display.setCursor(70,50);
display.println("C");
display.setCursor(63,48);
display.println("o");
display.display();
delay(100);
This works as expected. I added an HC06 Bluetooth module and tested it independently using some default code I found online. It worked as expected also.
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(5, 4); // RX | TX
Serial.println("Arduino with HC-06 is ready");
// HC-06 default baud rate is 9600
BTSerial.begin(9600);
Serial.println("BTserial started at 9600");
// Keep reading from HC-06 and send to Arduino Serial Monitor
if (BTSerial.available())
Serial.write(BTSerial.read());
// Keep reading from Arduino Serial Monitor and send to HC-06
if (Serial.available())
BTSerial.write(Serial.read());
However, when I combined the two, the display.begin fails and gives me the "failed to access OLED..." error as programmed. I have tried both with the Bluetooth code in separate function and with it in the void loop. I've tried so many troubleshooting steps, and even tried replacing the SoftwareSerial library with NeoSWSerial but to no avail. I'm at my wits end so if any of you have any idea what the problem could be, I'd be very grateful. The code I currently have is as follows (I know it's not super clean but it's just temporary whilst I get everything working at once)
#include <NeoSWSerial.h>
#include <Adafruit_BusIO_Register.h> //
NeoSWSerial BTSerial(5, 4); // RX | TX
int Temp = 0;
SFE_BMP180 tempsensor;
#define ALTITUDE 71
void setup(){
if (tempsensor.begin())
else{
while(1);
//display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
for(;;);
tempsense();
bluetooth();
void tempsense(){
char status;
double T;
status = tempsensor.startTemperature();
if (status != 0)
delay(status);
status = tempsensor.getTemperature(T);
if (status != 0)
Serial.print(T,2);
display.println(T);
display.display();
delay(100);
void bluetooth(){
Thanks in advance!
