Hi all, this is my first post so please inform me of any potential mistakes I'm making.
The appended sketch (that I have already reduced to the minimum for this error) compiles without issues for an Arduino Nano with a ATmega328P (Old bootloader, doesn't work on new bootloader at all).
However, when uploading the sketch or resetting the Nano, the setup is only running to the display.begin(i2c_Address, true);
line and (according to the serial monitor, which should count up the loops) crashes and restarts, which is observable in the Serial Monitor.
If I now comment out either the paragraph for the display (lines 123-127) OR the lines for the VESC, which uses softwareSerial (lines 20, 117, 118, 148 and 202-217), the code runs flawlessly, but is without much use to me. For context: VESC is a kind of motor speed controller.
I have read this StackOverflow-thread which blames an overflowing buffer, but was unable to find one aswell as this one which says that RAM is running out. ยด While I find that to be the more obvious answer, I'm unable to confirm this (and I have no idea how to).
Any help with this issue would be greatly appreciated. If there are any major issues in my coding, I'd happily receive feedback.
Thank you all in advance!
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#include <VescUart.h>
#include <SoftwareSerial.h>
//Adresses
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // QT-PY / XIAO
#define rxPin 5
#define txPin 4
//Objects
VescUart vesc;
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
SoftwareSerial vescSerial = SoftwareSerial(rxPin, txPin); // RX, TX
//Variables
int i = 1;
int PotiWert;
int GasProzent;
int vescNunchuk;
int Drehzahl;
int Eingangsspannung;
int Amperestunden;
int Tachometer;
const int Gyro1 = 0x68;
const int Gyro2 = 0x69;
float AccXHolm, AccYHolm, AccZHolm;
float gAccXHolm, gAccYHolm, gAccZHolm;
float AngleXHolm, AngleYHolm;
float AccXBrett, AccYBrett, AccZBrett;
float gAccXBrett, gAccYBrett, gAccZBrett;
float AngleXBrett, AngleYBrett;
const unsigned char MobiliTechLogo [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x03, 0xc7, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00,
0x1c, 0x00, 0x38, 0x00, 0x01, 0xe0, 0x03, 0xef, 0x3c, 0xff, 0xfc, 0x00, 0x00, 0x00, 0xf0, 0x00,
0x3c, 0x00, 0x78, 0x00, 0x01, 0xe0, 0x01, 0xcf, 0x3d, 0xff, 0xfc, 0x00, 0x00, 0x00, 0xf0, 0x00,
0x1e, 0x00, 0x78, 0x00, 0x01, 0xe0, 0x00, 0x0f, 0x01, 0xff, 0xfc, 0x00, 0x00, 0x00, 0xf0, 0x00,
0x1f, 0x00, 0xf8, 0x00, 0x01, 0xe0, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0xf0, 0x00,
0x1f, 0x00, 0xf8, 0x1f, 0x81, 0xef, 0x81, 0xcf, 0x3c, 0x07, 0x80, 0xfc, 0x01, 0xf8, 0xf3, 0xe0,
0x1f, 0x81, 0xf8, 0x3f, 0xe1, 0xff, 0xe1, 0xcf, 0x3c, 0x07, 0x83, 0xfe, 0x07, 0xfc, 0xff, 0xf0,
0x1f, 0x81, 0xf8, 0x7f, 0xf1, 0xff, 0xf1, 0xcf, 0x3c, 0x07, 0x87, 0xff, 0x0f, 0xfe, 0xff, 0xf8,
0x1f, 0xc3, 0xf8, 0xf0, 0xf9, 0xf0, 0xf1, 0xcf, 0x3c, 0x07, 0x87, 0x87, 0x9f, 0x0e, 0xfc, 0x78,
0x1d, 0xe7, 0xb8, 0xe0, 0x79, 0xe0, 0x79, 0xcf, 0x3c, 0x07, 0x8f, 0x03, 0x9e, 0x00, 0xf8, 0x38,
0x1c, 0xe7, 0x39, 0xe0, 0x39, 0xe0, 0x79, 0xcf, 0x3c, 0x07, 0x8f, 0x03, 0x9c, 0x00, 0xf0, 0x3c,
0x1c, 0xff, 0x39, 0xe0, 0x39, 0xe0, 0x79, 0xcf, 0x3c, 0x07, 0x8f, 0xff, 0x9c, 0x00, 0xf0, 0x3c,
0x1c, 0x7e, 0x39, 0xe0, 0x39, 0xe0, 0x79, 0xcf, 0x3c, 0x07, 0x8f, 0xff, 0x9c, 0x00, 0xf0, 0x3c,
0x1c, 0x7c, 0x39, 0xe0, 0x79, 0xe0, 0x79, 0xcf, 0x3c, 0x07, 0x8f, 0x00, 0x1e, 0x00, 0xf0, 0x3c,
0x1c, 0x3c, 0x38, 0xf0, 0xf9, 0xf0, 0xf1, 0xcf, 0x3c, 0x07, 0x87, 0x82, 0x1e, 0x0c, 0xf0, 0x3c,
0x1c, 0x18, 0x38, 0xff, 0xf1, 0xff, 0xf1, 0xcf, 0x3c, 0x07, 0x87, 0xff, 0x0f, 0xfe, 0xf0, 0x3c,
0x3c, 0x00, 0x38, 0x7f, 0xe1, 0xff, 0xe1, 0xcf, 0x3c, 0x07, 0x83, 0xff, 0x07, 0xfc, 0xf0, 0x3c,
0x1c, 0x00, 0x38, 0x1f, 0xc1, 0xcf, 0xc1, 0xcf, 0x3c, 0x07, 0x80, 0xfe, 0x03, 0xf8, 0xf0, 0x38,
Serial.println("serial begun.");
vescSerial.begin(19200);
Serial.println("vescSerial begun.");
Wire.begin();
Serial.println("wire begun.");
delay(250); //waiting for components to power up
Serial.println("display begun.");
display.clearDisplay();
display.drawBitmap(0, 0, MobiliTechLogo, 128, 64, 1);
display.display();
Wire.beginTransmission(Gyro1);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
Serial.println("gyro1 begun.");
Wire.beginTransmission(Gyro2);
Wire.write(0x6B);
Wire.write(0);
Serial.println("gyro2 begun.");
NeigungHolmMessen();
NeigungBrettMessen();
PotiMessen();
VESCMessen();
Serial.print("loop done x");
Serial.println(i);
i++;
void NeigungHolmMessen() {
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(Gyro1, 6, true);
AccXHolm = (Wire.read() << 8 | Wire.read());
AccYHolm = (Wire.read() << 8 | Wire.read());
AccZHolm = (Wire.read() << 8 | Wire.read());
gAccXHolm = AccXHolm / 16384;
gAccYHolm = AccYHolm / 16384;
gAccZHolm = AccZHolm / 16384;
AngleXHolm = (atan(gAccYHolm / sqrt(pow(gAccXHolm, 2) + pow(gAccZHolm, 2))) * 180 / PI) - 0.58;
AngleYHolm = (atan(-1 * gAccXHolm / sqrt(pow(gAccYHolm, 2) + pow(gAccZHolm, 2))) * 180 / PI) + 1.58;
void NeigungBrettMessen() {
Wire.write(0x3B);
AccXBrett = (Wire.read() << 8 | Wire.read());
AccYBrett = (Wire.read() << 8 | Wire.read());
AccZBrett = (Wire.read() << 8 | Wire.read());
gAccXBrett = AccXBrett / 16384;
gAccYBrett = AccYBrett / 16384;
gAccZBrett = AccZBrett / 16384;
AngleXBrett = (atan(gAccYBrett / sqrt(pow(gAccXBrett, 2) + pow(gAccZBrett, 2))) * 180 / PI) - 0.58;
AngleYBrett = (atan(-1 * gAccXBrett / sqrt(pow(gAccYBrett, 2) + pow(gAccZBrett, 2))) * 180 / PI) + 1.58;
void PotiMessen() {
PotiWert = analogRead(A0);
void VESCMessen() {
if ( vesc.getVescValues() ) {
Serial.println(vesc.data.rpm);
Serial.println(vesc.data.inpVoltage);
Serial.println(vesc.data.ampHours);
Serial.println(vesc.data.tachometerAbs);
Serial.println("Failed to get data!");
