Display command on serial and telnt (optimisation)
Hi in my program i have some debug that i want to display for debug. The user can be connected by serial or by telnet.
For the moment i have the same write 2 time for example for "Debug xxxxx" (it's bigger in the program)
Serial.print(F("Debug xxxxx"));
Telnet.print(F("Debug xxxxx"));
My first idea is to create a function
String displayDebug() {
answer+="Debug xxxxx";
answer+="xxxxx"
return answer;
Serial.print(displayDebug()));
Telnet.print(displayDebug());
But i thing that the string answer can be long an take many memory
Do you have an idea ?
Not sure I follow what you want. This is what I use for debug printing. You can add to the Macros as needed.
EDIT: corrected a typo in the sketch
  Blink
 Turns on an LED on for one second, then off for one second, repeatedly.
 This example code is in the public domain.
#define DEBUG       //If you comment this line the DPRINT & DPRINTLN
//lines are defined as blank.
//examples:
//DPRINTLN("Testing123");
//DPRINTLN(0xC0FFEEul,DEC);
//DPRINTLN(12648430ul,HEX);
#ifdef DEBUG
#define DPRINT(...)    Serial.print(__VA_ARGS__)
#define DPRINTLN(...)  Serial.println(__VA_ARGS__)
#define DRINTF(...)    Serial.print(F(__VA_ARGS__))
#define DPRINTLNF(...) Serial.println(F(__VA_ARGS__))
#else
#define DPRINT(...)    //blank line
#define DPRINTLN(...)  //blank line
#define DPRINTF(...)    //blank line
#define DPRINTLNF(...)  //blank line
#endif
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
int z = 123;
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  digitalWrite(led, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(led, LOW);   // turn the LED off by making the voltage LOW
  DPRINTLNF("This is in flash");
  DPRINTLN( z );
  DPRINTLN();
Thanks LarryD,
But on my side i want to send on different place the same information for example date and time the function is
String printDateTime(){
    answer ="";
    answer +=(RTC.year);
    answer +=("/");
    answer +=(RTC.month);
    answer +=("/");
    answer +=(RTC.day);
    answer +=(" - ");
    answer +=(RTC.hour);
    answer +=(":");
    answer +=(RTC.minute);
    answer +=(":");
    answer +=(RTC.second);
    return answer;
And i use like
Serial.print(printDateTime());
Telnet.print(printDateTime());
Make two functions with the serial output you want displayed. CALL the functions as needed.
Most here would suggest you never use String as it can lead to memory problems.
