Display DHCP information on Arduino
HI Everyone
I am trying to build an arduino project that displays “Dhcp information” on a 4 line lcd.
There is a video I have seen on youtube that is exactly what I want,i copied the code and libraries but unsucessfull.The guy who made this project doesn’t reply to me and I would like assistance from you Arduino crew please.On the
His link :
The compiler stops at “Socket was not declared”
PLEASE HELP ME
His Code I copied:
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);
byte mac = {
0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02
String ip = “”;
String subnetmask = “”;
String gateway = “”;
String dhcpserver = “”;
String dnsserver = “”;
SOCKET pingSocket = 0;
char buffer [255];
while (!Serial) {
lcd.init();
lcd.backlight();
while(1==1) {
EthernetClient client;
lcd.setCursor ( 0, 0 );
lcd.print(" ------------------ “);
lcd.setCursor ( 0, 1 );
lcd.print(”| DER GROSSE |");
lcd.setCursor ( 0, 2 );
lcd.print("| MUTATO |");
lcd.setCursor ( 0, 3 );
lcd.print(“±-----------------+”);
lcd.setCursor ( 0, 2 ); //
if(Ethernet.begin(mac,2000,2000) == 1)
lcd.clear();
client.stop();
printIPAddress();
printsubnetmask();
printgateway();
printdnsserver();
while(1 == 1) {
if(ping()==1){
lcd.clear();
delay(2000);
int ping()
ICMPPing ping(pingSocket);
byte pingAddr = { Ethernet.gatewayIP()[0],Ethernet.gatewayIP()[1],Ethernet.gatewayIP()[2],Ethernet.gatewayIP()[3]};
ping(1, pingAddr, buffer);
char *p = buffer;
char str;
char
buffer[20];
int x=0;
while((str = strtok_r(p,"[",&p))!=NULL){
buffer=str;
x++;
String checkping= buffer[0];
if(checkping!=“Reply”)
return 1;
return 0;
void printIPAddress()
for (byte thisByte = 0; thisByte < 4; thisByte++) {
ip+=Ethernet.localIP()[thisByte], DEC;
if (thisByte < 3)
ip+= “.”;
lcd.print( “IP | " + ip );
ip=”";
void printsubnetmask()
subnetmask+=Ethernet.subnetMask()[thisByte], DEC;
if (thisByte < 3)
subnetmask+= “.”;
lcd.print( “SN | " + subnetmask );
subnetmask=”";
void printgateway()
gateway+=Ethernet.gatewayIP()[thisByte], DEC;
if (thisByte < 3)
gateway+= “.”;
lcd.print( “GW | " + gateway );
gateway=”";
void printdnsserver()
dnsserver+=Ethernet.dnsServerIP()[thisByte], DEC;
if (thisByte < 3)
dnsserver+= “.”;
lcd.print( “DNS| " + dnsserver );
dnsserver=”";
Put code tags around your code. This is a good example of how the forum system mangles the code otherwise.
#include <SPI.h>
#include <Dns.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
  // this check is only needed on the Leonardo:
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // print your local IP address:
  Serial.print("IP: ");
  Serial.println(Ethernet.localIP());
  Serial.print("Gateway: ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("Subnet: ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("DNS: ");
  Serial.println(Ethernet.dnsServerIP());
HI Surfer Tim and Pylon
Thank you kindly for both your responses.
@ Surfer Tim
Your code is genius looks so much more organised and professional,its just that i want to display it on a 20 x 4 lcd .As you have it showing on serial monitor is perfect,just want that on an LCD pleased.
i really don't mean to be annoying.
:confused: :confused:
Hey guys
Me again.
After copying codes from other projects,i get this.
I would still like a clean display,and a home screen “Zahed Hoosen” when no IP address detected.
Post the code that generated that display and use code tags! (that’s the </> button in the editor)
Thank you so much Guys.
Everything is working as it should be.
Appreciate all the assistance received
My project is working how i want it to.
