Display Error from Serial Monitor when connect with ESP2866
I’m a new bie. I try to connect arduino uno with ESP2866. It’s ok. But when it display information from ESP2866 to Serial Monitor. I only see unknown characters.
Please Explain for me.
thank you!
Sorry. My device is ESP8266. I can't see where editing my topic!
try baud rates
57600 or 115200
Older models have a default 115200
My newer ESP-12 original firmware has a default of 9600 (but contains the newer AT command to change the default).
The bootloader uses 74880 (you’ll need a different serial monitor as the IDE does not support this speed).
When i tranmit AT+RST: Serial Monitor print:
L(CÇäÿÿæc@ˆþ„@JSÀ€àà
[Vendor:www.ai-thinker.com Version:0.9.2.4]
ready
I have try change baud, from “Both NR & CR to Carriage return”.
115200 : can’t not see anything. Nothing happened.
It’s seem problem in display infomation, how about encoding with chip or IDE of arduino?
pYro_65: Older models have a default 115200
The bootloader uses 74880 (you'll need a different serial monitor as the IDE does not support this speed).
Hi! so What can i do know?
