Display image on 1.8 st7735 128X160 spi TFT module
Hi
I'm trying to display image on 1.8 st7735 128X160 SPI TFT module with esp32 board, successfully dumped the code with no errors and in terminal I'm getting like this:image
I'm getting that file is not found so
I have double checked my sd card also and here I have used this below code:
  This is a library for the Adafruit 1.8" SPI display.
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
//include library code
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
#include <mySD.h>
//define pins of TFT screen
#define TFT_CS     12
#define TFT_RST    14
#define TFT_DC     13
#define TFT_SCLK   22
#define TFT_MOSI   21
//define pins of SD card slot
#define SD_CS    5
#define SD_MOSI  23
#define SD_MISO  19
#define SD_SCK   18
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
void setup(void) {
  Serial.begin(115200);//initialise serial communication at 115200 bps
  tft.initR(INITR_BLACKTAB);//initialise tft screen
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS, SD_MOSI, SD_MISO, SD_SCK)) {//initialise SD card
    Serial.println("SD card failed!");
    return;
  Serial.println("SD card initialised!");
  bmpDraw("parrot.bmp", 0, 0);//draw picture from SD card, do not forget to change the file name here
  delay(2000);//wait 2 seconds
// uncomment these lines to draw bitmaps in different locations/rotations!
//change the name here!
 /* tft.fillScreen(ST7735_BLACK); // Clear display
  for(uint8_t i=0; i<4; i++)    // Draw 4 parrots
    bmpDraw("parrot.bmp", tft.width() / 4 * i, tft.height() / 4 * i);
  tft.setRotation(tft.getRotation() + 1); // Inc rotation 90 degrees
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint8_t y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print("Loading image '");
  Serial.print(filename);
  Serial.println('\'');
   //gets(filename);
    //fflush(stdin);
  //  fputs(filename,bmpFile);
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.print("File not found");
    Serial.print(bmpFile);
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.print("File size: "); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print("Image Offset: "); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print("Header size: "); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print("Bit Depth: "); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print("Image size: ");
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        tft.setAddrWindow(x, y, x+w-1, y+h-1);
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each pixel...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format, push to display
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            tft.pushColor(tft.color565(r,g,b));
          } // end pixel
        } // end scanline
        Serial.print("Loaded in ");
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println("BMP format not recognized.");
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
this below condition is not satisfying so getting "file is not found":
<  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.print("File not found");/>
so what will be the reason and how to fix this please help me.
Thank you for your time
