display interger to a ekitszone LCD cant convert to char
I have tried and tried to get this sorted for ages, and I am having to resort to asking on here, (sorry) I know this is probably an obvious one for some of you guys. I have been only playing with arduino's now for two years, still alot to learn, anyway...
Have a Ekitszone 2 line LCD and I am trying to display three temperatures on it,
the three intergers are tture1 tture2 and tture3 and I need to display them to the lcd with one decimal place only
funny thing is in another project, using a 128 colour LCD display this never was a problem. I think the library for that LCD has int conversion biult in, but Im not knowledgable enough to sift through it.
/*ReadDS18B20three
Reading three DS18B20s
#include <LCD4Bit_mod.h>
#include <stdio.h>
LCD4Bit_mod lcd = LCD4Bit_mod(2);
#define tture1 2
#define tture2 3
#define tture3 10
//from readTture(Pin), and to send data to printTture...
int pumpon = false;
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
  lcd.init();
  lcd.clear();
  lcd.printIn("CT");
  lcd.cursorTo(2, 0);
  lcd.printIn("BT");
  lcd.cursorTo(2, 8);
  lcd.printIn("Pump");
  lcd.cursorTo(1, 10);
  lcd.printIn("TT");
    //For each tture sensor: Do a pinMode and a digitalWrite
    pinMode(tture1, INPUT);
    pinMode(tture2, INPUT);
    pinMode(tture3, INPUT);
    digitalWrite(tture1, LOW);//Disable internal pull-up.
    digitalWrite(tture2, LOW);
    digitalWrite(tture3, LOW);
    delay(300);//Wait for newly restarted system to stabilize
    Serial.print("Temperature measurement, two sensors:\n\n\n");
void loop(){
  readTture(tture1);//N.B.: Values passed back in globals
  printTture();//N.B.: Takes values from globals. Also...
     //no newline part of pritTture;
  Serial.print("   ");
  delay(220);// Delay... must not be too short.
  readTture(tture2);//Now read and report 2nd tture.
  printTture();
  Serial.print("  ");//Start new line
  readTture(tture3);//N.B.: Values passed back in globals
  Serial.print("\n");
  //lcd.cursorTo(1, 2);  //line=2, x=0
    //  lcd.printIn(tture1);                                //this of course wont work
  if (pumpon == false) {
      lcd.cursorTo(2, 13);
      lcd.printIn("OFF");
      if (pumpon == true) {
        lcd.printIn("ON");
void OneWireReset(int Pin) // reset.  Should improve to act as a presence pulse
     digitalWrite(Pin, LOW);
     pinMode(Pin, OUTPUT); // bring low for 500 us
     delayMicroseconds(500);
     pinMode(Pin, INPUT);
}//end OneWireReset
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
   byte n;
   for(n=8; n!=0; n--)
      if ((d & 0x01) == 1)  // test least sig bit
         delayMicroseconds(5);
         delayMicroseconds(60);
      d=d>>1; // now the next bit is in the least sig bit position.
}//end OneWireOutByte
byte OneWireInByte(int Pin) // read byte, least sig byte first
    byte d, n, b;
    for (n=0; n<8; n++)
        b = digitalRead(Pin);
        delayMicroseconds(50);
        d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
    return(d);
}//end OneWireInByte
void readTture(byte Pin){
//Pass WHICH pin you want to read in "Pin"
//Returns values in... (See global declarations)
  OneWireReset(Pin);
  OneWireOutByte(Pin, 0xcc);
  OneWireOutByte(Pin, 0x44); // perform temperature conversion, strong pullup for one sec
  OneWireReset(Pin);
  OneWireOutByte(Pin, 0xbe);
  LowByte = OneWireInByte(Pin);
  HighByte = OneWireInByte(Pin);
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's comp
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  Whole = Tc_100 / 100;  // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
};//end readTture
void printTture(){//Uses values from global variables.
//See global declarations.
//N.B.: No new line inside printTture
if (SignBit) // If it's negative
     Serial.print("-");
  Serial.print(Whole);
  Serial.print(".");
  if (Fract < 10)
     Serial.print("0");
  Serial.print(Fract);
};//end printTture
alrite...I worked it out a different way....
silly mistake in there also....no one spotted it??
anyway here to share....
working code its actually a 3 sensor Hot water system controller, have not put in the pump control output yet. Easy to do.
/*ReadDS18B20three
#include <stdio.h>
#include <stdlib.h>
#define tture1 2
#define tture2 3
#define tture3 10
int pumpon = false;
  lcd.init();
  lcd.clear();
  lcd.printIn("CT");
  lcd.cursorTo(2, 0);
  lcd.printIn("BT");
  lcd.cursorTo(2, 8);
  lcd.printIn("TT");
void loop(){
  Serial.print("   ");
  lcd.cursorTo(1, 12);  //line=2, x=0
  printTture();
  lcd.cursorTo(2, 2);  //line=2, x=0
  Serial.print("  ");
  Serial.print("\n");
      lcd.printIn("OFF");
        lcd.printIn("ON");
}//end OneWireReset
   byte n;
   for(n=8; n!=0; n--)
    byte d, n, b;
    for (n=0; n<8; n++)
    return(d);
  OneWireReset(Pin);
  OneWireReset(Pin);
};//end readTture
     Serial.print("-");
  Serial.print(".");
  if (Fract < 10)
     Serial.print("0");
  char temp [33];
  itoa (Whole,temp,10);
lcd.printIn(temp);
};//end printTture
