display more than one
i have problem,with my code(here with)( made helping with forum specially Mr.strerretj). my project is measure level and volume by 2 ultrasonic (tank and reservoir)that levels and time , date display one by one (with updating lcd) in system standby mode(3 things).in motor automatically on/run ,that time display only tank level .those are basic functions & in my mind i need to add few buttons to control on motor manually/auto,and time period and also level wise & time manually adjust.And also levels display led 7 segment max7219 module
i am beginner still learn arduino,many of codes dont understand (like millis)
my problem is code levels not updating and changing and scrolling,pls anyone can help me further for this
#include <LiquidCrystal.h>
#define trigger1 11
#define echo1 10
#define trigger2 12
#define echo2 13
LiquidCrystal lcd(8,9,4,5,6,7);
// it's a 16x2 LCD so...
float time=0;
#define DISPLAY_TANKINFO 20
#define SCROLL_TANKINFO 21
#define DISPLAY_RESERVOIRINFO 22
#define SCROLL_RESERVOIRINFO 23
#define DISPLAY_PUMPSTATUS 24
#define SCROLL_PUMPSTATUS 25
#define DISPLAY_DATETIME 26
#define SCROLL_DATETIME 27
#define DELAY_TANK2RESERVOIR 28  // delay step between display of tank info and reservoir info
#define DELAY_RESERVOIR2TANK 29
byte currentDisplay = DISPLAY_TANKINFO;
unsigned long currentTime=0;
int tankLevel;
int reservoirLevel;
 lcd.begin(16,2),
 pinMode(trigger1,OUTPUT);
 pinMode(echo1,INPUT);
 pinMode(trigger2,OUTPUT);
 pinMode(echo2,INPUT); // put your setup code here, to run once:
  readTankLevel();
  readReservoirLevel();
   switch (currentDisplay)
    case DISPLAY_TANKINFO:
      displayTankInfo();
      currentDisplay = SCROLL_TANKINFO;
    case SCROLL_TANKINFO:
      if (scrollDisplayLeft(500, 16) == true)
        currentDisplay = DELAY_TANK2RESERVOIR;
    case DELAY_TANK2RESERVOIR:
      if(wait(1500) == true)
        currentDisplay = DISPLAY_RESERVOIRINFO;
    case DISPLAY_RESERVOIRINFO:
      displayRsvInfo();
    case SCROLL_RESERVOIRINFO:
        currentDisplay = DELAY_RESERVOIR2TANK;
     case DELAY_RESERVOIR2TANK:
  read the tank level
void readTankLevel()
  digitalWrite(trigger1, LOW);
  delayMicroseconds(2);
  digitalWrite(trigger1, HIGH);
  delayMicroseconds(10);
  time = pulseIn(echo1, HIGH);
  tankLevel = (140 - (time * 340 / 20000)) / 1.3;
  read the tank level
void readReservoirLevel()
  digitalWrite(trigger2, LOW);
  digitalWrite(trigger2, HIGH);
  time = pulseIn(echo2, HIGH);
  reservoirLevel = (140 - (time * 340 / 20000)) / 1.3;
  setup the display to show the tank information
void displayTankInfo()
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Tank Level: ");
  lcd.print(tankLevel);
  lcd.setCursor(15, 0);
  lcd.print("%");
  lcd.setCursor(0, 1);
  lcd.print("volume   : ");
  lcd.print(tankLevel * 5);
  lcd.setCursor(14, 1);
  lcd.print("Lt");
void displayRsvInfo()
  lcd.clear();
  lcd.print("Rsv Level: ");
  lcd.print(reservoirLevel);
  lcd.print("%");
  lcd.print("vole   : ");
  lcd.print(reservoirLevel * 5);
  lcd.print("Lt");
  scroll the display left
  In:
    duration for each step (in ms)
    number of steps
  Returns:
    true if scroll completed, flase if scroll in progress
bool scrollDisplayLeft(unsigned long stepDuration, byte numSteps)
  static unsigned long lastUpdateTime = 0;
  static byte positionCounter = 0;
  unsigned long currentTime = 0;
  if (currentTime - lastUpdateTime >= stepDuration)
    lastUpdateTime = currentTime;
    lcd.scrollDisplayLeft();
    positionCounter++;
    if (positionCounter >= numSteps)
      return true;
  return false;
  check if a duration has lapsed
  In:
    duration (in ms)
  Returns:
    false if duration has not lapsed, else true
bool wait(unsigned long duration)
  static unsigned long startTime;
  static bool isStarted = false;
  // if wait period not started yet
  if(isStarted == false)
    // set the start time of the wait period
    startTime = currentTime;
    // indicate that it's started
    isStarted = true;
    // indicate to caller that wait period is in progress
    return false;
  // check if wait period has lapsed
  if(currentTime - startTime >= duration)
    // lapsed, indicate no longer started so next time we call the function it will initialise the start time again
    isStarted = false;
    // indicate to caller that wait period has lapsed
    return true;
  return false;
Punctuation would REALLY improve this stream of consciousness.
Sowouldsomespacesandcarriagereturns.
What a waste of effort.
The code does something. You completely failed to provide even the vaguest hint of what it does.
You expect the code to do something. I can't begin to decipher what that is.
#define motor 8
#define buzzer 1
#define lcdled 2
Why do you #define a value for motor, when you never use it? It makes it look like you have the LCD and motor on the same pin.
Why do you #define a value for buzzer, when you never use it?
Moderator: Cross post removed
some codes not write like motor(relay).other one is my mistake. first i am a beginner,not a expert ,i want to learn.learn from example codes..some codes not understand to me,but i try. i want to made some motor pump control circuit and code (simple one i can make) like i said before.if you can help pls do it.
