display not changing contrast dramatically depending on what is displayed
I am using Basic 16x2 Character LCD - White on Black 3.3V - LCD-09052 - SparkFun Electronics on an Arduino Uno, IDE 1.0.5 on Windows7.
When I try to write to the display, a string ending in punctuation will not work (LCD goes blank), but the same string without punctuation at the end works. Even if I just use another letter at the end, it works, and if I use a “:” it does not.
Luckily I can just exclude punctuation in this case, but this seems really strange so I was wondering: has anyone else seen this and has an idea what is going on?
Program is supposed to cycle between displaying “wait for it” and “hit”; when I end either string with punctuation LCD remains blank for that second. I included a line that will work, commented out, and one that does not.
Here is the code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  lcd.begin(16, 2);
   lcd.clear();
  //lcd.print("wait for it"); // works
  lcd.print("wait for it."); //doesn't work
  lcd.clear();
  lcd.print("hit");
Update: it turns out the display isn’t staying blank, but instead the contrast changes so dramatically between the “hit” and the “wait for it” that it looks like blank unless I up the contrast to the point where the “hit” is almost unreadable. What would cause that?
Is it connected to 5V or 3.3V rail on your Arduino?
The power for both the backlight and the controller are connected to 3.3V. I am not sure what you mean by "rail", though...
