Hi
I have created a newer bar graph from previous sketches that work, but this one does not display the sensor value at the bottom, just shows 0. I am pretty sure it is something simple, but cant pick it up in the code
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
uint16_t tx, ty;
// Global Variables
float enginetemp;
float oilpressure;
float boostpressure;
float exhuasttemp;
int tempPin = 0; //temp sensor
int oilPin = 1; //oil sensor
int boostPin = 2; //boost sensor
int egtPin = 3; //egt sensor
int tempValue = 0;
int tempPercent = 0;
int oilValue = 0;
int oilPercent = 0;
int boostValue = 0;
int boostPercent = 0;
int egtValue = 0;
int egtPercent = 0;
//int RawValue = 0;
int LastPercent0 = 0; // temp grapgh
int LastPercent1 = 0; // oil graph
int LastPercent2 = 0; //boost graph
int LastPercent3 = 0; //egt graph
Serial.println("RA8875 start");
//Initialize the display using 'RA8875_480x80', 'RA8875_480x128', 'RA8875_480x272' or 'RA8875_800x480'
if (!tft.begin(RA8875_800x480))
Serial.println("RA8875 Not Found!");
while (1);
Serial.println("Found RA8875");
tft.displayOn(true);
tft.GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft.PWM1out(255);
tft.textMode();
displayvalue();
void displayvalue()
{Serial.begin(9600);
while (1);
tft.PWM1out(255);
tft.textMode();
tft.PWM1out(255);
tft.textMode();
tft.textSetCursor(10, 10);
tft.textColor(RA8875_WHITE, RA8875_BLACK);
tft.textEnlarge(8);
tft.textWrite(" Temp Oil Boost EGT");
char Tempstring[30];
char Oilstring[30];
char Booststring[30];
char Exhuaststring[30];
dtostrf(enginetemp, 2, 0, Tempstring); //from temp float
dtostrf(oilpressure, 2, 0, Oilstring); //from oil float
dtostrf(boostpressure, 2, 0, Booststring); //from boost float
dtostrf(exhuasttemp, 2, 0, Exhuaststring); // from egt float
tft.PWM1out(255);
tft.textMode();
tft.textColor(RA8875_CYAN, RA8875_BLACK);
tft.textEnlarge(2);
tft.textSetCursor(80, 399);
tft.textWrite(Tempstring);
tft.textWrite(" *C");
tft.textColor(RA8875_YELLOW, RA8875_BLACK);
tft.textEnlarge(2);
tft.textSetCursor(270, 399);
tft.textWrite(Oilstring);
tft.textWrite(" Psi");
tft.textEnlarge(2);
tft.textColor(RA8875_GREEN, RA8875_BLACK);
tft.textSetCursor(460, 399);
tft.textWrite(Booststring);
tft.textEnlarge(2);
tft.textSetCursor(650, 399);
tft.textWrite(Exhuaststring);
void drawBartemp (int nPer0) {
if (nPer0 < LastPercent0) {
tft.fillRect(110, 50 + (350 - LastPercent0), 100, LastPercent0 - nPer0, RA8875_BLACK);
else {
tft.fillRect(110, 50 + (350 - nPer0), 100, nPer0 - LastPercent0, RA8875_CYAN);
LastPercent0 = nPer0;
void drawBaroil (int nPer1) {
if (nPer1 < LastPercent1) {
tft.fillRect(300, 50 + (350 - LastPercent1), 100, LastPercent1 - nPer1, RA8875_BLACK);
else {
tft.fillRect(300, 50 + (350 - nPer1), 100, nPer1 - LastPercent1, RA8875_YELLOW);
LastPercent1 = nPer1;
void drawBarboost (int nPer2) {
if (nPer2 < LastPercent2) {
tft.fillRect(490, 50 + (350 - LastPercent2), 100, LastPercent2 - nPer2, RA8875_BLACK);
else {
tft.fillRect(490, 50 + (350 - nPer2), 100, nPer2 - LastPercent2, RA8875_GREEN);
LastPercent2 = nPer2;
void drawBaregt (int nPer3) {
if (nPer3 < LastPercent3) {
tft.fillRect(680, 50 + (350 - LastPercent3), 100, LastPercent3 - nPer3, RA8875_BLACK);
else {
tft.fillRect(680, 50 + (350 - nPer3), 100, nPer3 - LastPercent3, RA8875_WHITE);
LastPercent3 = nPer3;
tempValue = analogRead(tempPin);
tempPercent = int((tempValue / 1024.0) * 310.0);
if (tempPercent != LastPercent0) {
drawBartemp(tempPercent);
oilValue = analogRead(oilPin);
oilPercent = int((oilValue / 1024.0) * 310.0);
if (oilPercent != LastPercent1) {
drawBaroil(oilPercent);
boostValue = analogRead(boostPin);
boostPercent = int((boostValue / 1024.0) * 310.0);
if (boostPercent != LastPercent2) {
drawBarboost(boostPercent);
egtValue = analogRead(egtPin);
egtPercent = int((egtValue / 1024.0) * 310.0);
if (egtPercent != LastPercent3) {
drawBaregt(egtPercent);
enginetemp = analogRead(tempPin);
enginetemp = (5.0 * enginetemp * 100.0) / 1024.0;
oilpressure = analogRead(oilPin);
oilpressure = (5.0 * oilpressure * 100.0) / 1024. / 5.8; //Display 0-70Psi
boostpressure = analogRead(boostPin);
boostpressure = (5.0 * boostpressure * 100.0) / 1024. / 14; //Display 0-30Psi
exhuasttemp = analogRead(egtPin);
exhuasttemp = (5.0 * exhuasttemp * 100.0) / 1024.*2; //Display 0-800
