Hello everyone
Sorry about my English..
I have to finish my final project so please try to help me ![]()
I'm using Arduino Mega
I have two flow sensor (hall sensor) and i'm trying to write the data about the flow on LCD (16X2) screen, but it displays only some rectangles
#include <LiquidCrystal.h>
#include <Wire.h>
Pulse Period Measurement of 2 Flow Sensors
• accurate measurements by using Arduino micros() function
• determines leading edge of pulses without use of iterrupts
• calculates pulse periods, frequencies, flow rates, totalized volumes
• includes pulse generator for testing, simulation and troubleshooting
• easily adapted for testing other sensors and pulse quantities (energy, optic, etc.)
- dlloyd ----------------------------------------------------------------------------*/
LiquidCrystal lcd(2,3,4,5,10,11,12);
// constants
const byte pgenPin = 13;Â // PGEN pin number
const byte CLEAR = 12;Â Â // CLEAR pin number
const byte inputs[] = {6, 8}; // input pins 6 is inlet 8 is outlet
const double pulseConstant[] = {7.5, 7.5}; // pulse constants
const byte qty = sizeof(inputs);
// variables
double pgenFrequency = 7.5;Â // pulse generator frequency (Hz)
long previousMillis = 0;
long pgenInterval = 1000000 / (pgenFrequency * 2);
byte pgenState = LOW;
long pgenPreviousMicros = 0;
long startTime[qty];
byte inputsState[qty];
byte inputsPrevious[qty];
double pulsePeriod[qty];
double pulseFrequency[qty];
double pulseMultiplier[qty];
double flowRate[qty];
double pulseVolume[qty];
double totalVolume[qty];
byte h0[8] = {
 B11111,
 B01010,
 B10101,
 B01010,
 B10101,
 B01010,
 B11111,
Serial.print("");
lcd.begin(16,2);
lcd.clear();
pinMode(pgenPin, OUTPUT);
pinMode(CLEAR, INPUT_PULLUP);
for (int i = 0; i < qty; i++) {
 pinMode(inputs[i], INPUT_PULLUP);
 pulseVolume[i] = 1.0 / (pulseConstant[i] * 60);
 pulseMultiplier[i] = 1.0 / (pulseConstant[i]);
Â
 //lcd.print(flowRate[i], 6); lcd.print(" m^3/sec, ");
 //lcd.setCursor(0,1);
   //lcd.print(flowRate[i+1], 6); lcd.print(" m^3/sec, ");
   //delay(1000);
   //lcd.clear();
clr(); // initialize arrays
pgen();Â // run pulse generator
if (digitalRead (CLEAR) == LOW) {Â // check CLEAR push button
 clr();
pulseMeasure();Â // run flow tests, calculations and print results
// functions -----------------------------------------------------
void pulseMeasure() {
 inputsState[i] = digitalRead(inputs[i]);         // read the inputs
 if ((inputsState[i] == 1) && (inputsPrevious[i] == 0)) { // if rising
  pulsePeriod[i] = (micros() - startTime[i]) * 0.000001; // test duration (sec)
  pulseFrequency[i] = 1 / pulsePeriod[i];         // input frequency (Hz)
  flowRate[i] = (pulseFrequency[i] * pulseMultiplier[i])*16.6666667;  // 1.0 / pulseConstant[i] (L/min) (ml/sec)
  totalVolume[i] = totalVolume[i] + pulseVolume[i];    // totalized volume (L)
  if (millis() - previousMillis > 250) {         // update interval (milliseconds)
   Serial.print(i); Serial.print(": ");
   Serial.print(pulsePeriod[i], 3); Serial.print(" sec, ");
   Serial.print(pulseFrequency[i], 3); Serial.print(" Hz, ");
   Serial.print(flowRate[i], 6); Serial.print(" ml/sec, ");
   lcd.print(flowRate[i], 6); lcd.print(" ml/sec, ");
   Serial.print(totalVolume[i], 6); Serial.print(" L");
   previousMillis = millis();
  startTime[i] = micros();
 inputsPrevious[i] = inputsState[i];
void pgen() {
// check to see if it's time to pulse the PGEN; that is, if the
// difference between the current time and last time you pulsed
// the PGEN is bigger than the interval to changed its output state.
unsigned long pgenCurrentMicros = micros();
if (pgenCurrentMicros - pgenPreviousMicros > pgenInterval) {
 // save the last time you pulsed the PGEN
 pgenPreviousMicros = pgenCurrentMicros;
 // if the PGEN output is off turn it on and vice-versa:
 if (pgenState == LOW)
  pgenState = HIGH;
  pgenState = LOW;
 digitalWrite(pgenPin, pgenState);
void clr() {
 inputsState[i] = 0;
 inputsPrevious[i] = 1;
 pulsePeriod[i] = 0;
 pulseFrequency[i] = 0;
 flowRate[i] = 0;
 totalVolume[i] = 0;
Someone have an idea?
(notice: I want to display on the screen only the data of flow rate)
Thank you
