display or manipulate floating number and String
Hello everybody,
I would like to display floating numbers with the UTFT module. I think that the simple manipulation of these numbers is the same problem. I found two methods to display floating numbers :
float yy = 123.456;
char buf[32];
sprintf(buf, "%f", yy);
myGLCD.print(buf, CENTER, CENTER);
this compile but the result is the display of the caracter "?" (interrogation point).
second method :
float yy = 123.456;
String ss = String(yy);
the compliation gives an error : call of overloaded 'String(double&)' is ambiguous
Now, about string, If I code :
String ss = "Hello";
char buf[32];
sprintf(buf, "%s",ss);
myGLCD.print(buf, CENTER, CENTRE),
this compiles, at the execution, it seems that the sprintf hangs the program.
So, it appears that the sprintf does'nt work with float and String variables.
How do you do to display floating numbers ?
Thank you for your help.
Pierre
See here:
http://forum.arduino.cc/index.php/topic,148214.0.html
There's a small library (formatDouble) that turns a float into a string.
Thank you Nick Gammon for library.
But furthr, can you explain me why :
double dd = 100/3;
int ent = floor(dd); // or double ent = floor(dd); --> the result is the same
double frac = dd - ent;
gives 0 as a result ?
Pierre
For enabling floats in sprintf (and sscanf) you can install this in \hardware\tools\avr\avr\lib (make a backup of that lib folder, and then extract and replace files): Arduino Forum
Another option is to use dtostrf (I believe it's more efficient, and use much less memory than sprintf with FP enabled): avr-libc: <stdlib.h>: General utilities
ChPr:
double dd = 100/3;
Pierre
Simple... 100/3 is 33. The floor() of 33 is 33. Subtract 33 from 33 and you get 0.
Now, if you were working with floating point numbers, then it would be different.
double dd = 100.0/3.0; // Note the subtle difference here - the .0 forces it to be floating point, not integer.
There's also the dtostrf() and dtostre() functions to convert floats to strings, two different ways.
Je vous remercie tous pour vos remarques, liens et idées que vous m'avez apportés.
Cordialement.
Pierre
ChPr:
Cordialement.
Pierre
ChPr (via Google Translate):
Thank you all for your comments, links and ideas that you have given me.
Cordially.
Pierre
Sorry and thank you majenko for the translation :wink:
Pierre
