Display RM68090
Hi guys! I have a display is RM68090 from China phone.
He has 29 pin. Hooked up to Arduino Nano pasted programming initialization and have result:
Initializing LCD...
Reading ID...0x0000
Loading LCD registers...
Filling the screen...
Done filling...
If your screen filled red, you may be able to use the library at http://misc.ws
From other scetch result
What needed to start this display?
All controllers operate at 2.8V to 3.3V. You will damage it with 5V from a Nano.
If you connect it with the correct voltages I will help you get it running.
It is not a Raydium RM68090
David.
david_prentice:
David.
David. I'm connected to 3.3 v pin and display backlight powered by a laboratory power supply.
A Nano has 5V GPIO. It will damage the controller.
Use a proper 3.3V board like Zero, Due, Nucleo, ...
I use a Uno clone with switchable 3V/5V e.g. Open-Smart or Seeed Studio
David.
david_prentice:
David.
I don't have Zero and other in my city. I'm need buying it from AliExpress or other. No way to run from Nano?
Yes, you can run it from a Nano. Just use thirteen level shifters.
david_prentice:
I bad understand English. It's a connected from resistors? Or not? If can show picture it's like.
It's like that
https://www.google.com.ua/search?ei=udv-W9CUC5eHwPAP6MykgA8&q=thirteen+level+shifter+arduino+&oq=thirteen+level+shifter+arduino+&gs_l=mobile-gws-wiz-serp.3..33i22i29i30l5.54184.58115..60729...0.0..0.314.1188.0j2j2j1......0....1j5.........0i71j33i160.AKo5hvnTKbE#imgrc=ShnDicreX0sdBM:
