Display screen I2C - U8g library - strange graphic!
Hi all
I have an I2C display from hantec, and have sussed out that I can use this with U8GLIB SSD1306 declaration:
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NO_ACK);
I have two displays of slightly different sizes that work in the same way, however the larger ones have a strange line down the side.
I'm 99% sure this is software-related because depending on where I write text to the screen it changes a bit, and sometimes when I change the code it almost completely goes away.
I tested resetting a number of times and the strange right hand graphic only ever changes when I change the code...
I don't mean "software fault", more "maybe I got the wrong settings".
Here's what I am seeing:
Any ideas?
how big is the screen in pixels?
have you tried a sketch that puts on/off all pixels every second?
for x=0 to maxX
for y =0 to MaxY
pixelon
delay(1000)
pixeloff
just to see if the pixels that form the line is addressabble
Maybe, this is a SH1106 controller (instead of the SSD1306):
U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NO_ACK);
Oliver
Win
Thanks Oliver!
